Date/Time: Fri, 31 Jan 2025 13:39:12 +0000
Add Plugins to Notepad++?
View Count: 783
[2019-05-11 04:07:20] |
maxpi - Posts: 181 |
Is it possible to add plugins to Notepad++ as it is installed with Sierrachart?
[2019-05-11 20:16:36] |
Sierra Chart - Max - Posts: 5780 |
Yes, you can add plugins. You can also use your own installation of Notepad++, or any other text/code editor. You just need to update the Daily Data Editor: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#DailyDataEditor And set the Editor under File >> Select Editor under Analysis >> Build Custom Studies DLL. Sierra Chart Support Date Time Of Last Edit: 2019-05-13 03:53:15
