Date/Time: Fri, 31 Jan 2025 13:55:52 +0000
Replay all charts in chartbook - some play, some don't
View Count: 848
[2019-05-11 01:10:36] |
sierrasimon - Posts: 51 |
Hello, when I replay all charts in chartbook, sometimes they play all at the same time, as they should, but a lot of times just a few replay, and when I click on pause they stop playing, but the others that did't play, now play or something like that. Is it a bug??
[2019-05-11 23:22:16] |
We definitely do not believe at all there is some kind of problem here. There is not going to be any consideration of that at all. There is some other explanation including the fact that you may have charts that are from other Chartbooks that are visible.
[2019-05-13 16:24:24] |
I do not beleave it neigther, but it is. It seems that SC has difficulties to calculate big amount of data. I had 4 charts in one chartbook with 5 months data loaded and about 15 studies in each. Everytime I wantet to replay, it loaded about a minute. Now, since i reduced the amount of data the problem I described didn't occur again.
[2019-05-14 12:57:58] |
Now I notice, that the problem persists even with reduced chart data.
