Date/Time: Fri, 31 Jan 2025 13:36:33 +0000
SC Historical data for AMP Futures
View Count: 1591
[2019-05-11 00:59:06] |
WarriorTrader2 - Posts: 3 |
Hello, I have an AMP Futures account with a complementary review of package 5 for the next month. Is "Sierra Chart Historical Data Service" available? I get an error message saying it is not included with my account type every time I attempt to download intraday minute data. I set up a separate copy of SC with the data feed set to "SC All Services" Thanks, WT |
[2019-05-11 16:54:31] |
WarriorTrader - Posts: 245 |
Hello, Forgot to add that I am using CQG with Amp Futures. Thx, -WT |
[2019-05-12 00:14:25] |
You will need a direct account for this: Direct Sierra Chart Account
When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
