Date/Time: Wed, 26 Feb 2025 09:46:38 +0000
drag chart with crosshair (chart values tool)
View Count: 1746
[2019-05-10 18:03:09]
grantx - Posts: 244
Why doesn't sierracharts have the functionality to click and drag the charts when in the crosshairs mode?
I have to keep going back to the hand tool then crosshair/hand tool /crosshair/hand tool - backwards and forwards.
Is there a tickbox somewhere that enables this?
[2019-05-10 18:13:26]
John - SC Support - Posts: 38172
No, what you are doing is the only way to perform the chart drag.
If you have not already done so, you can setup a Control Bar with the tool selections to be able to switch between the settings a little bit quicker. Refer to the information here on customizing control bars:
Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings)
[2019-05-12 04:01:46]
There is support for exactly what you want by setting the Chart Values tool to always be on with Action When Other Tools Selected:
Chart Drawing Tools: Chart Values Tool Configuration
Date Time Of Last Edit: 2019-05-12 04:02:23
[2021-05-16 01:05:13]
User740271 - Posts: 12
Is there a way to be in 'hand' mode:
then left click causing both:
1. 'grab' (which does happen)
2. see the cross-hair (which does not happen)
I think I could do this in the previous version. Thank you.
Date Time Of Last Edit: 2021-05-16 17:33:52
[2021-05-17 14:18:45]
Yes, as specified above, you need to set the setting for Action When Other Tools Selected to Always Enabled when Using Other Tools. Refer to the information here:
Chart Drawing Tools: Action When Other Tools Selected (Global Settings >> Tool Settings >> Chart Values >> Chart Values)
