Date/Time: Fri, 31 Jan 2025 13:40:01 +0000
changing the way the volume number is displayed
View Count: 674
[2019-05-10 17:10:36]
MMX - Posts: 119
I have enabled the "Display Entire Profile Volume" option in the Volume By Price study and the volume number prints this way... "V: 3517". Is it possible to have the volume print "3517" instead of "V: 3517"?
[2019-05-10 18:01:33]
John - SC Support - Posts: 37621
Yes, this was made available in a recent release. Refer to the following Input for the Volume by Price study:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#Input_ShowTextLabels
Also, as noted, this was a recent change, so you may need to update to the latest release. To do so, you can use the Fast Update option. The instructions can be found here:
