Date/Time: Fri, 31 Jan 2025 13:01:59 +0000
trading problem
View Count: 611
[2019-05-10 16:14:25]
User357583 - Posts: 4
The last couple days I am getting a 3 to 5 second delay between clicking the mouse for entry on dom and actually seeing the order present on dom . Everything seems to slowed down. I have good internet connection (720 mbps) Task manager shows around 14% CPU use for SC. Data flash is using 3% really not running much else using a total 22% on CPU.. It has affected my trading .. thanks for your help.
[2019-05-10 16:21:03]
Sierra Chart - Max - Posts: 5780
1. You need to post questions using your active Sierra Chart account. To automatically log into the Support Board select Help >> Support Board from within Sierra Chart.
2. For high CPU usage refer to help topic 30 here:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
Sierra Chart Support
Date Time Of Last Edit: 2019-05-10 16:22:21
