Date/Time: Fri, 31 Jan 2025 12:44:41 +0000
Yes to All No to All while closing cbs & saving spreadsheets
View Count: 576
[2019-05-10 12:44:57] |
ILIM KIRGIZ - Posts: 187 |
I have a chartbook with 32 different spreadsheets. Each time I close the chartbook I need to click Yes button 32 times. Is there an option to Save Them All while closing the chartbook? Thanks. |
[2019-05-10 17:17:33] |
Sierra Chart - Max - Posts: 5780 |
You can try the following work around. Instead of closing down the Chartbook and Spreadsheets, you can try to close down Sierra Chart, this will give you the "Save All" option. Closing down and Starting Sierra Chart should be much faster than clicking through 32 dialogs.
Sierra Chart Support |
