Date/Time: Fri, 31 Jan 2025 13:55:22 +0000
Sierra Chart Fxcm connection trade performance trade statistic
View Count: 758
[2019-05-10 06:50:27]
User364859 - Posts: 26
Hello
If I open the trade activity log I get only blancs (0) numbers.
I have clicked all internal order ID2, all symbols(no sim), account xxxxxxxx, all notes
and then apply ? Result: only blanc numbers, may bee you can help me with team viewer access?
Or what can I do ?
Thanks for a quick help
Walter Zegg
Date Time Of Last Edit: 2019-05-10 15:45:07
[2019-05-10 17:11:19]
Sierra Chart - Max - Posts: 5780
1. First question is have you done any trading using your FXCM demo account?
2. What are the Date Range to Display settings?
Sierra Chart Support
Date Time Of Last Edit: 2019-05-10 18:50:13
[2019-05-10 19:18:27]
Hello
Yes I trades since End of April 2019 with the connected fxcm account and I have seen the results on the Orders and position side.
Dae range is : 2019-05-01 to 2019-05-10 23:00h
[2019-05-12 03:16:04]
Take a screenshot of the Trade Activity Log and attach it here following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
Date Time Of Last Edit: 2019-05-12 03:16:41
[2019-05-12 14:52:26]
Hello
The instructions are too complicated, I can't upload this file, I can send you the screen shot, if you give me a e-mail adress or I have teamviewer for remote access?
Thank you
Walter Zegg
imageSierraChart_Trade activity log_Mai10.jpg / V - Attached On 2019-05-12 14:23:28 UTC - Size: 329.82 KB - 253 views
[2019-05-13 01:05:38]
Ok the problem is quite clear.
Do the following:
From the menu at the top select Trade Activity.
At the top left in the list of activity types, select "All Activity". Currently it is set to Account Balances.
Date Time Of Last Edit: 2019-05-13 01:05:52
