Date/Time: Fri, 31 Jan 2025 13:00:46 +0000
Subgraphs Reference Study - Color Fill-In not lining up correctly
View Count: 720
[2019-05-09 18:10:04]
jakesans - Posts: 50
SC,
I am using the Subgraphs Reference Study to link two lines each from a different study with the goal of coloring in between those two lines using the transparent fill to top and bottom. It isn't lining up correctly. Is there something I am doing wrong or some setting I am missing?
Thanks,
Jake S.
Private File
[2019-05-09 20:35:36]
John - SC Support - Posts: 37621
Set the Scale for the Study Subgraphs Reference Study to Automatic. By default it is set to Independent, which is why you are seeing what you are seeing. The documentation for how to access the scale for a study can be found here:
Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study
And here is the documentation on setting the Scale Range:
Chart Scale and Scale Adjusting: Scale Range (Scale Settings)
