Date/Time: Fri, 31 Jan 2025 13:01:22 +0000
Market Depth Bitmex changed
View Count: 765
[2019-05-09 16:06:17]
User465507 - Posts: 74
Since I updated Sierra I've noticed Bitmex market depth is now capped. I can only see about 70 levels worth & same for the depth recording. It no longer records the full depth. Was this done intentionally? Is there no way to get the 'full depth' back?
I've checked in data/trade service settings that max time & sales depth level is 0 and same within chart settings.
[2019-05-09 16:11:55]
There is this new setting which controls this:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels
This is something really unique. It is not something commonly available with market data services. Being able to control the number of market depth levels actually transmitted from the server is good.
You may just want to set it to 0 so there is no restriction.
Date Time Of Last Edit: 2019-05-09 16:12:04
[2019-05-09 23:12:40]
ok, great, i found the setting you're referring to & have changed it. Everything is functioning as expected now.
