Date/Time: Fri, 31 Jan 2025 12:58:27 +0000
[Programming Help] - Ray and Line Drawing Tools Unstable
View Count: 650
[2019-05-09 14:48:29] |
tesseract353 - Posts: 66 |
When I use the Make Line Parallel command in order to make 2 Rays parallel to each other. The one that is being made parallel, does become parallel to the other, but only temporarily. As more bars print on the chart, the line that was made parallel, becomes unparalleled. If this is by design, it is making the use of lines impossible to rely on since they are moving around. I've observed similar behavior when the Cut Drawing Here command is used on a Ray, as more bars print on the chart, the end of the Line (that use to be a Ray), on the side closest to the right side of the chart begins to move around - again making it impossible to rely on the accuracy of that drawing. Date Time Of Last Edit: 2019-05-09 14:50:26
[2019-05-10 02:35:22] |
The reason for this is explained here: Lines/Rays or Other Chart Drawings Move After Drawing Them Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
