Date/Time: Fri, 31 Jan 2025 12:36:29 +0000
Getting Overfill Message
View Count: 667
[2019-05-09 12:54:39] |
User94606 - Posts: 327 |
I am getting an overfill message when I closed my NQ position - see screenshot. Can you explain what is the message suppose to mean?
Overfill.jpg / V - Attached On 2019-05-09 12:54:23 UTC - Size: 205.04 KB - 264 views |
[2019-05-09 15:07:19] |
You are using Interactive Brokers. This indicates, they are sending more execution reports than match up with the actual order fills. You need to contact them about this. Another user reported this about a week ago as well. It is harmless, but it certainly is not good at all for it to be happening. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-09 15:20:27
