Date/Time: Fri, 31 Jan 2025 12:51:56 +0000
Tabs have become indistinguishable
View Count: 614
[2019-05-09 12:41:47] |
User541156 - Posts: 67 |
Since the whole tab system was upgraded, all tabs just appear in the same line without any dividers. There is no separation between them. Can this be looked at, please? Date Time Of Last Edit: 2019-05-09 12:42:52
2019-05-09_22-08-58.png / V - Attached On 2019-05-09 12:42:49 UTC - Size: 3.42 KB - 251 views |
[2019-05-09 15:05:02] |
This has already been resolved. Update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
