Date/Time: Fri, 31 Jan 2025 12:39:39 +0000
using 2 different time frames for an auto trade
View Count: 605
[2019-05-09 12:41:22]
User996274 - Posts: 94
Can the AT system activate using 2 different time frames for the same product?
example say i wanted to enter on a 5min chart but close on a 1min reversal
I wud have the "Studies" trading system based on alert
programmed as follows
Buy entry 5min if ........
Buy exit 1min if......
If both AT's are active wud they conflict?
[2019-05-09 17:09:01]
We do not see any problem with this. One of the studies would do an entry and the other do an exit. This should work just fine.
