Date/Time: Thu, 26 Sep 2024 23:30:01 +0000
Number bars with Delta volume bars?
View Count: 1436
[2013-11-24 21:17:44] |
MonteCarlo64 - Posts: 23 |
Can I see the bid/ask volume at price (number bars) inside delta volume bars in Pkg #5?
[2013-11-24 21:20:56] |
Yes. This is fully supported.
