Date/Time: Fri, 31 Jan 2025 12:38:58 +0000
Chart Window
View Count: 592
[2019-05-09 12:11:48] |
User56044 - Posts: 62 |
Chart window DyPL is not correctly displaying the true amount of P/L. Using IB and Sierra Chart 1915. Is some setting amiss? What to do?
[2019-05-09 16:58:15] |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
