Date/Time: Fri, 31 Jan 2025 21:06:58 +0000
Chart Tool Values Window - removing Focus
View Count: 721
[2019-05-09 06:04:24] |
HAB-User115006 - Posts: 38 |
I activate the 'Chart Tool Values Window' by using the Crosshair tool, the Values window pops up and now has the focus. Now if I want to scroll the chart I cannot unless I click on the Title bar of the chart or some where on the Main window and then scroll, the Values window remains visible but I have to force a defocus from the values window with a click. This behavior is not seen in the Compat tool. Can get very tedious after sometime. SUGGESTION: After activating the Values window put the focus back on the chart chart Window that activated it, similar to the compact tool window behavior. Thanks... |
[2019-05-09 17:06:28] |
This will be solved in the next release.
[2019-05-11 00:53:14] |
Thank you for addressing this Enhancement Request so rapidly... Look forward to seeing it in the next release
[2019-06-02 07:41:06] |
Confirmed it works, Thanks!
