Date/Time: Fri, 31 Jan 2025 12:40:54 +0000
Can't Find Micro e-mini symbols
View Count: 1201
[2019-05-09 02:19:15] |
User809389 - Posts: 3 |
I updated Symbol Settings from server: Global Settings >> Symbol Settings, but I still cannot find any new symbols. What is Sierra symbol for the NQ and ES Micro e-mini? thanks
[2019-05-09 03:05:01] |
We see you are using CTS and we did not set up the new symbols on CTS.
[2019-05-09 03:18:22] |
Ok. Are you planning to add the new symbols to CTS? If so when? Thanks |
[2019-05-09 14:24:57] |
tesseract353 - Posts: 66 |
I would like to know this as well. Date Time Of Last Edit: 2019-05-09 14:25:52
[2019-05-09 16:58:44] |
Yes. We will try to get these out today.
[2019-05-09 17:03:06] |
Great! Thanks so much. I appreciate you assistance.
