Date/Time: Fri, 31 Jan 2025 11:47:24 +0000
chartbook from additional files
View Count: 759
[2019-05-08 22:14:10] |
tbillm - Posts: 8 |
have a chartbook from additional files i want to use but can not figure out how to download it into chartbook file, it says put it into data folder box but the download file is no where to be found???????????????? thankyou very much
[2019-05-08 22:32:22] |
John - SC Support - Posts: 37621 |
In general, on the Windows Operating System, files that are selected in a browser are placed into the Downloads folder for your Windows account. That is the place to check and see if it is there and then copy it to the Data folder for Sierra Chart. There are a lot of other possibilities on where it could be placed based on your Operating System version, the particular browser you are using, etc. So it is not possible for us to give you exact information, you will need to figure out where the file is being placed on your system. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-08 22:57:58] |
tbillm - Posts: 8 |
https://www.sierrachart.com/AdditionalFiles/CCI_with_Avg.StdyCollct trying to obtain this chtbook |
[2019-05-08 22:59:02] |
tbillm - Posts: 8 |
i did place it imto the data file but the program does not chow it under chartbook
[2019-05-09 03:09:15] |
This is a Study Collection file. Refer to: How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
