Date/Time: Fri, 31 Jan 2025 12:08:38 +0000
Hot Key
View Count: 603
[2019-05-08 19:32:15] |
User509820 - Posts: 69 |
Is there a way to program a hot key to buy with attached orders and program a key to buy with attached orders. I don’t want to keep toggling the attached orders button. Thanks |
[2019-05-09 03:09:59] |
There is a way to enable and disable Attached Orders with a keyboard shortcut: Basic Trading and the Trade Window: Trading Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
