Date/Time: Fri, 31 Jan 2025 12:02:53 +0000
Bad data
View Count: 619
[2019-05-08 17:32:55] |
EdCarp - Posts: 25 |
Every other day or so, I have data corruption issues where the volume information in the data is incorrect. When I select "delete all data and download", the volume data is correct. Is there a setting in Sierra that would possibly be incorrect that would cause this issue? |
[2019-05-09 03:31:07] |
No, this is an external data feed issue.
