Date/Time: Fri, 31 Jan 2025 12:08:25 +0000
[Programming Help] - Compare VAP with VAP in the future
View Count: 677
[2019-05-08 17:09:18]
JDMontero - Posts: 34
Hi.
I'm trying to do a "Manual" extend line until future intersection because I need to refer and extended line, and the "extend line until future intersection" of the color bar based on alert condition does not store the values of each line it creates (Which would be useful to have... 1 subgraph for each line created)
So I tried setting the condition alert of the color bar based on alert study to have the condition AND have the future bars above the low of the present bar, so that then I can refer it if the alert value is still 1 after a certain amount of bars:
IF AND condition to draw the line, L[1]>L , L[2]>L, L[3]>L.... etc. But seemed archaic and soon realized there is a limit amount of characters.
Then tried for "color if VAP of low of present bar equals VAP so many bars in the future", but this doesn't seem to work either.
1) Can VAP be compared with VAP in the future for a condition alert?
2) Could I compare a range of bars with a line and color only if Line < range of bars ? Tried but does not seem to work.
3) How else could I make a condition line that I can refer to only if it has not been intersected? I'm trying to pull the VAP trick but with outputted volume in the spreadsheets
4) Is there a practical way to discriminate a value (A line I already have stored as a value in the subgraph for line extension of color bar on alert) in the spreadsheets once price has crossed it?
