Date/Time: Fri, 31 Jan 2025 12:02:52 +0000
How can I download an Old Spreadsheet version of SC?
View Count: 1011
[2019-05-08 15:59:34]
User12222 - Posts: 20
I tried downloading using the "Previous Versions", but it appears version 1310 or earlier is not supported as it did not download. I am looking for version 1310 or earlier. I tried the spreadsheet conversion by trying to open in a recent version of SC but the message log said that conversion failed. I am not going to trade with the old version, I just want to open up my chart file and corresponding spreadsheet to see what I did so I can redo for the current version. Please Help! Thanks
[2019-05-08 20:40:20]
You can obtain version 1310 from this page:
https://www.sierrachart.com/index.php?page=doc/SCInstallerList.php
Then just run the executable that you downloaded and it will run through the installation process.
Also you can provide us your spreadsheet files from the older Sierra Chart version and we will convert them for you. You can privately attach them through this Support Board thread. We are happy to do the conversion. We have done that for many users.
