Date/Time: Sun, 24 Nov 2024 18:44:45 +0000
Moving horizontal lines
View Count: 1709
[2013-11-24 09:54:01]
Kenneth.S - Posts: 20
Is it possible to move the horizontal line chart-drawings using just a single left click (line dragging).
Mine works like this:
I have to select the line with the left mouse button, then i have to click the mouse button a again to begin moving the line.
I would prefer it to work like this:
I left-click and hold with the mouse pointer on the line and I can then move the line - when i release the mousebutton the line is released at the position of the cursor and this becomes its new position. The lines position should update while dragging.
[2013-11-26 03:49:04]
This is supported. Can be enabled with Global Settings >> Tool Settings >>Support Drag for Drawing Creation/Modification.
[2013-11-26 20:01:12]
I have that setting enabled - however the behavior is like this:
I have to click the line to select , release the left mouse button and click the left mouse button again to start dragging.
I would like to be able to drag it when clicking (and holding) the first time.
[2013-11-26 20:15:48]
We see what you mean. We have to look into this.
[2013-11-28 04:23:06]
Al SC Developer - Posts: 434
Resolved in ver 1055, when available.
