Date/Time: Fri, 31 Jan 2025 12:53:37 +0000
MJNK evening end time is wrong
View Count: 873
[2019-05-08 08:39:36] |
User745789 - Posts: 356 |
Correct: 05:29:59 https://www.jpx.co.jp/english/derivatives/rules/trading-hours/index.html |
[2019-05-09 04:33:36] |
I cant be 100% sure it was the cause, but after changing the evening end time to the correct in the global symbol settings, I now note that the Sessions Indicator study no longer aligns with the time scale. Minor, but maybe points to a larger time-scale issue*, so I mention it here. See attached. Blue line = evening session. Correct end time is 05:30 Yellow = day session. Starts at 08:45 ////// [*Different issue, but it might explain some frustrations I am having gettingthe VbP study to do what I want wrt time, per these various settings: Volume By Price Study: Examples of Input Settings for Different Volume Profiles] Date Time Of Last Edit: 2019-05-09 04:35:37
sessions.PNG / V - Attached On 2019-05-09 04:33:33 UTC - Size: 5.38 KB - 280 views |
[2019-05-10 03:19:32] |
We have updated the session times for this futures market according to the Regular Session column in this table: Explanation of Time Schedule: https://www.jpx.co.jp/english/derivatives/rules/trading-hours/index.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
