Date/Time: Fri, 31 Jan 2025 12:09:53 +0000
[Programming Help] - DOM Quantities Messed Up
View Count: 606
[2019-05-08 05:03:45] |
User483121 - Posts: 3 |
I'm experiencing a problem with the quantities showing up on the DOM. In the attached picture, you can see: 1) The second-to-last Offer is not displaying correctly. It looks like a combination of two numbers mixed together 2) There are gaps in the Bids at the bottom A combination of these two things will happen frequently throughout the day, sometimes worse than this, making it very difficult to trade using market depth. |
[2019-05-08 05:11:49] |
We are declining support for this because we cannot help with it. For reliable data feed, use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed We do not help with Gain Capital data problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
