Date/Time: Fri, 31 Jan 2025 11:49:17 +0000
[User Discussion] - Dynamic chart header
View Count: 683
[2019-05-08 04:19:51]
User629461 - Posts: 184
Hi, is there an option/switch that allows the chart header to dynamically update basic information (ie OHLC, volume etc) based on the cursor position instead of having to open one the Tools Value windows every time?
[2019-05-08 04:52:24]
Not, unless you scroll the chart back. Instead use the Compact Tool Values window:
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools
Date Time Of Last Edit: 2019-05-08 04:52:52
[2019-05-08 11:37:26]
Not sure how difficult this is or how many others would use, but is there any chance of adding this as a functionality? The Tool Values window always gets in the way of something, so i'm constantly opening then closing it.
[2019-05-08 17:37:10]
User364630 - Posts: 13
+10
[2019-05-08 17:40:54]
There is no chance of this.
