Date/Time: Thu, 26 Sep 2024 23:34:05 +0000
connect Sierra with Ineractive Brokers
View Count: 1264
[2013-11-24 08:31:45] |
User67944 - Posts: 3 |
HI could you help me please how to connect Sierra with TWS Interactive Brokers. I already set up API in TWS but it is still not working. Do you know where is the mistake. Thank you Universe |
[2013-11-24 09:03:00] |
We need to see what the Message Log shows. Please provide it by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
