Date/Time: Fri, 31 Jan 2025 11:51:56 +0000
Trailing Stop with Auto Trading System
View Count: 1537
[2019-05-07 21:26:00]
User235492 - Posts: 16
Hi SC,
How do I add a trailing stop to the automatic trading system?
Thanks,
Dennis
[2019-05-08 05:41:23]
Do you mean as an attached order, attached to a parent order?
And how is the automated trading system implemented in Sierra Chart?
[2019-05-08 12:17:49]
Hi SC,
I believe i figured it out. Orders can be placed through the study "Trading System". But to add brackets and trialing stops, I need to use the Chart DOM which will execute the orders based on trailing stop or whatever bracket system I have set up.
Thanks,
Dennis
[2019-05-08 17:29:34]
You can use the Trading System Based on Alert Condition study and then on the chart that it is applied to, set up the Attached Orders through its Trade Window as documented here:
Attached Orders: Using Attached Orders and Attached Order Settings
This does not involve the Chart DOM.
Date Time Of Last Edit: 2019-05-08 17:30:29
