Date/Time: Fri, 31 Jan 2025 12:57:10 +0000
Pivot Points Variable Period
View Count: 1022
[2019-05-07 19:15:55] |
User371906 - Posts: 141 |
Hello, I have Pivot Points Variable Period and want to be able to able see the current pivot lines and not show the past ones. Is there a way to do this as there is not option in the settings. http://www.sierrachart.com/image.php?Image=1557256105666.png Settings attached. Thank you g |
Attachment Deleted. Pivot Points Variable Period Settings.JPG / V - Attached On 2019-05-07 19:12:40 UTC - Size: 86.45 KB - 249 views |
[2019-05-08 03:58:49] |
The only Input setting available related to this as you know is the Number of Days to Calculate.
[2019-05-08 08:03:46] |
Thank you for reply, Agree, the only input settins is Number of Days to Calculate, but I have seen other SC charts that have these lines not shown up in there charts. Is there a other study or way that would facilitate this? Kindly Date Time Of Last Edit: 2019-05-08 08:04:18
[2019-05-09 09:21:35] |
Hello, Anybody interested in having only one line in Pivot Points Variable Period can do it by placing Draw Style in: Line at Last Bar to Left Side |
[2019-05-09 11:36:06] |
Ackin - Posts: 1865 |
Custom study is possible, if do you want this, you can write request on forum. Ackin's indicators (SCH users requests for studies) - Update list | Post: 178661 |
[2019-05-09 12:16:12] |
Ackin, Thanks for offer. Kindly |
