Date/Time: Fri, 31 Jan 2025 12:12:23 +0000
Pivot Point Plotting
View Count: 908
[2019-05-07 17:38:26] |
Usuario - Posts: 19 |
Hello. I'm migrating from Ninja and I'm really enjoying SC. But one thing I miss is a more "discrete" Pivot Points plotting. Is there any way to reduce the length of the lines so they do not cover the entire time range? I have tried removing the lines completely and leaving only "label" and "value label" on the right, but it is a bit confusing. Some line is needed. I´ve tried with dots, dark colours... In Ninja you can choose the percentage of line you want: if you want to cover all day frame, or 25%, 10% ... having a more legible and clean graphic. Any option for this? Thank you. |
[2019-05-09 04:06:56] |
You can control the number of days to calculate: Pivot Points: Number of Days To Calculate You can also use this particular Subgraph Draw Style: Chart Studies: Line at Last Bar to Edge (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
