Date/Time: Fri, 31 Jan 2025 12:04:58 +0000
[Programming Help] - Audio Alerts
View Count: 565
[2019-05-07 16:50:12] |
Jock Cameron - Posts: 3 |
I have no skills in programming - I want a simple thing . . . I want a sound when the RSI drops below 30 eg 'ding' - then another below 20 eg 'ding ding' another below 10 eg 'ding, ding, ding' and one when the RSI returns above 30 eg 'beep'. I want a similar set of audios for 70/80/90 and dropping back through 70. Could someone please help me with this?
[2019-05-08 17:39:42] |
Basically you will want to use a formula like this with the RSI study: =CROSSOVER (SG1, 30) You will also need a separate RSI study for each condition where you want to have a different sound play. So you would need to add six RSI studies to the chart since you want to have six different sounds. Here is the relevant documentation: Study/Chart Alerts And Scanning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
