Date/Time: Sun, 24 Nov 2024 17:39:50 +0000
connect data with Interactive Brokers
View Count: 1155
[2013-11-24 08:25:35] |
User67944 - Posts: 3 |
Hi could you help me please to connect Siera with ineactive Brokers. I alreadz set up API in TWS Interactive Brokers but it still not working. Do you know, whre could be a problem. I am using MacBook for a TWS and Sierra is working on Windows8 with Pararells. SO I don't know if this is problem. Thank you for your help. |
[2013-11-25 18:02:25] |
We need to see the Message Log. Provide it by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
