Date/Time: Fri, 31 Jan 2025 12:02:52 +0000
Spreadsheet Study behavior difference between sierra data feed and CQG feed
View Count: 653
[2019-05-07 07:33:29]
User978290 - Posts: 25
Hi, I would like to know if anything can be done.
When using sierra feed, with chart settings
New york local time
intraday 1 min
symbol: NQM19
Days to load: 1
Start time: 09:30:00
End time: 16:00:00
Spreadsheet Study
Login to sierra Time: 09:00:00
The spreadsheet study would not start to populate until Start time at 09:30:00 which is perfect! (spreadsheet study is blank until 09:30:00)
However, when using CQG feed - Osaka exchange, it populates instantly the data from previous day. (spreadsheet study already have data in it before 08:45:00)
The settings is the same except for
JP local time
Start time: 08:45:00
End time: 15:15:00
Symbol: F.US.MJNKM19
Login to sierra Time: 08:30:00
Can the Osaka feed/spreadsheet study behave like sierra? Thx
[2019-05-08 05:51:44]
Really we are not understanding this. You need to show us a screenshot of the spreadsheet to show us what you mean.
[2019-05-08 08:35:10]
Don't think a screenshot would do much. I will try to keep it simple. Forget the spreadsheet study.
When I load the chart for NQ 15mins before market open. The chart is Blank there is nothing just black.
But when I load the chart for F.US.MJNKM19 15mins before market open. The chart is Loaded with the previous day data.
Both charts are set to their respective local time and have "Use Number of Days to load" in Chart > Main Settings set to 1
How can I mimic the NQ behavior F.US.MJNKM19 with ?
All the settings seems to be the same. Perhaps there is a time in sierra where it Counts as next day differently between 2 markets?
Date Time Of Last Edit: 2019-05-08 08:35:50
[2019-05-08 15:41:23]
There is not a solution to this because the basic problem is the NQ symbol is a 24 hour market and the other one is not. When there is no trading in the current day, then when loading 1 day, the the prior day is going to get loaded. So inherently the result you see is all technically correct.
