Date/Time: Fri, 31 Jan 2025 10:58:31 +0000
Sierra Chart does not recognize DLLs dropped into Data Folder
View Count: 665
[2019-05-06 20:49:43] |
User630735 - Posts: 2 |
Hello. I am currently using Sierra Chart through Infinity Futures. I would like to start using Sierra Chart through Amp Futures via CQG. I got a demo account to test how to transfer my DLLs, study collections and chartbooks directly to the Sierra Chart Data folder instead of the SierraChartTransActMA Data folder. The DLLs are in the Sierra Chart DATA folder. However, Sierra chart does not find them. It loads the study collections via "ANALYSIS" However, I get error messages such as the following: "CreateStudyDLLModuleFunctionObjectErrorLoadingC:\SierraChart\Data\Vstop.dll. Windows error code 126: The specified module could not be found. Likely missing dependency file)|0ms|CalcOrder:7"
[2019-05-07 04:01:51] |
Usually this is going to mean that a DLL has a dependency on other DLLs which are not present. So you need to contact the developer of that particular DLL.
