Date/Time: Sun, 24 Nov 2024 22:37:31 +0000
Enhancement...
View Count: 1501
[2013-11-23 22:46:43] |
C. Notes - Posts: 129 |
I have a quick enhancement thought that has been nagging me for some time... I enjoy use of the cycle tool in certain situations. Especially on longer timeframes. I believe it would benefit the tool greatly to add vertical lines to the nodes on the tool for more accurate alignment. Lines at the midpoint between nodes would be helpful as well. Seems this would be a very simple addition that could only add to the usefulness of the tool. As it is the tool must be "eyeballed" into position. In my experience the benefits of a cycle tool shine on longer term charts. "eyeballing" on these charts can lead to a discrepancy of days. My thoughts.. Cheers |
[2013-11-25 05:08:14] |
namlem - Posts: 94 |
+1
[2013-11-25 09:32:30] |
jbetlach - Posts: 30 |
May I ask which study are you guys talking about? |
[2013-11-25 09:56:15] |
Menu Tools -> Cycle (Ctrl+Alt+Y)
[2013-11-25 09:58:57] |
Thank you very much! |
[2013-11-26 01:30:12] |
Thanx for the vote Namlem! More votes pleeaze! |
[2013-11-26 07:57:35] |
+1 for sure.
[2013-11-27 02:28:14] |
Ah...up +3 ticks Let's see if we can get a rally here! lol |
[2013-12-11 09:43:09] |
We will see about this. Should not be difficult to do this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-11 09:43:51
[2013-12-14 19:56:52] |
Al SC Developer - Posts: 434 |
When available, ver 1063 adds new cycle tool features to allow the cycle node and mid-points to have vertical lines drawn. These are off by default, but can be turned on per drawing and in the drawing configurations for future drawings. There is also an option that will allow the vertical lines to be drawn only when the drawing is being modified.
[2013-12-17 04:01:09] |
Awesome! Thanks much - You guys rock! |
