Date/Time: Fri, 31 Jan 2025 10:55:20 +0000
logg in to td ameritrade account
View Count: 602
[2019-05-06 15:10:09]
User624194 - Posts: 1
I am not be able to connect to my td ameritrade account through Sierra chart
Reading Internal Order ID file. | 2019-05-06 14:46:45
Reading Trade Orders file. | 2019-05-06 14:46:45
Reading Trade Positions file. | 2019-05-06 14:46:45
Reading Account Balance file. | 2019-05-06 14:46:45
UDPListener (1416). Port 22904 | Listening on UDP port 22904. | 2019-05-06 14:46:45
Software version: 1915 32-bit | 2019-05-06 14:46:45
Usage end date: 2019-05-17 | 2019-05-06 14:46:45
Enabled for: Advanced Features. | 2019-05-06 14:46:45
Enabled for: Advanced Features 2. | 2019-05-06 14:46:45
Enabled for: Sierra Chart Historical Data Service. | 2019-05-06 14:46:45
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-05-06 14:46:45
Current selected Data/Trading service: TD Ameritrade | 2019-05-06 14:46:45
Chart Update Interval: 500 | 2019-05-06 14:46:45
Intraday Data Storage Time Unit: 1 | 2019-05-06 14:46:45
Time Zone: +00:00:00 (UTC+00) | 2019-05-06 14:46:45
2019-05-06 10:46:44 Local computer time | 2019-05-06 14:46:45
2019-05-06 14:46:44 Local computer time in UTC | 2019-05-06 14:46:45
2019-05-06 14:46:44 Local computer time in SC Time Zone | 2019-05-06 14:46:45
2019-05-06 14:46:45 Server time in UTC | 2019-05-06 14:46:45
Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-05-06 14:46:45
Program path: C:\SierraChart\ | 2019-05-06 14:46:45
Data Files path: C:\SierraChart\Data\ | 2019-05-06 14:46:45
OS Version Number: 10.0 | 2019-05-06 14:46:45
Locale Setting: C | 2019-05-06 14:46:45
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-05-06 14:46:45
Checking for new symbol settings. Requested symbol settings MD5 for service code tda. Request ID: 1. | 2019-05-06 14:46:45
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-05-06 14:46:45
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-05-06 14:46:45
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:45
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:46:45
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-05-06 14:46:45
Received 5 login tokens. | 2019-05-06 14:46:46
Symbol settings MD5 received. Request ID: 1. | 2019-05-06 14:46:46
Symbol settings are up-to-date for tda. | 2019-05-06 14:46:46
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:46
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:46
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:46:46
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-05-06 14:46:46
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-05-06 14:46:46
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-05-06 14:46:46
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:46:47
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-05-06 14:46:47
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:48
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:46:48
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-05-06 14:46:48
TD Ameritrade | Connecting. | 2019-05-06 14:46:51
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:46:51
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:46:51
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:46:51
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:46:51
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:46:51
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:46:51
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:46:51 *
TD Ameritrade | Login failed. | 2019-05-06 14:46:51 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:46:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:46:51
TD Ameritrade | Disconnected. | 2019-05-06 14:46:51
Disconnected from TD Ameritrade. | 2019-05-06 14:46:51
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:46:51
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:51
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:51
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:46:51
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Closed. | 2019-05-06 14:46:51
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:46:51
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Closed. | 2019-05-06 14:46:51
TD Ameritrade | Connecting. | 2019-05-06 14:46:54
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:46:54
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:46:54
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:46:54
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:46:54
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:46:54
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:46:54
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:46:55 *
TD Ameritrade | Login failed. | 2019-05-06 14:46:55 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:46:55
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:46:55
TD Ameritrade | Disconnected. | 2019-05-06 14:46:55
Disconnected from TD Ameritrade. | 2019-05-06 14:46:55
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:46:55
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:55
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:55
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:46:55
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (2) | Closed. | 2019-05-06 14:46:55
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:46:55
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (1) | Closed. | 2019-05-06 14:46:55
TD Ameritrade | Connecting. | 2019-05-06 14:46:58
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:46:58
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:46:58
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:46:58
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:46:58
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:46:58
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:46:58
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:46:58 *
TD Ameritrade | Login failed. | 2019-05-06 14:46:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:46:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:46:58
TD Ameritrade | Disconnected. | 2019-05-06 14:46:58
Disconnected from TD Ameritrade. | 2019-05-06 14:46:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:46:58
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:58
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:46:58
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:46:58
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (1) | Closed. | 2019-05-06 14:46:58
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:46:58
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Closed. | 2019-05-06 14:46:58
TD Ameritrade | Connecting. | 2019-05-06 14:47:01
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:01
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:01
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:01
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:01
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:01
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:01
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:02 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:02 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:02
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:02
TD Ameritrade | Disconnected. | 2019-05-06 14:47:02
Disconnected from TD Ameritrade. | 2019-05-06 14:47:02
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:02
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:02
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:02
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:02
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (2) | Closed. | 2019-05-06 14:47:02
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:02
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (1) | Closed. | 2019-05-06 14:47:02
TD Ameritrade | Connecting. | 2019-05-06 14:47:05
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:05
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:05
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:05
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:05
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:05
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:05
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:05 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:05 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:05
TD Ameritrade | Disconnected. | 2019-05-06 14:47:05
Disconnected from TD Ameritrade. | 2019-05-06 14:47:05
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:05
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:05
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:05
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:05
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (2) | Closed. | 2019-05-06 14:47:05
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:05
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (1) | Closed. | 2019-05-06 14:47:05
TD Ameritrade | Connecting. | 2019-05-06 14:47:08
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:08
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:08
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:08
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:08
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:08
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:08
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:09 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:09
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:09
TD Ameritrade | Disconnected. | 2019-05-06 14:47:09
Disconnected from TD Ameritrade. | 2019-05-06 14:47:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:09
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:09
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:09
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:09
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (1) | Closed. | 2019-05-06 14:47:09
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:09
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (2) | Closed. | 2019-05-06 14:47:09
TD Ameritrade | Connecting. | 2019-05-06 14:47:12
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:12
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:12
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:12
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:12
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:12
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:12
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:12 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:12
TD Ameritrade | Disconnected. | 2019-05-06 14:47:12
Disconnected from TD Ameritrade. | 2019-05-06 14:47:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:12
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:12
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:12
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:12
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (2) | Closed. | 2019-05-06 14:47:12
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:12
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (1) | Closed. | 2019-05-06 14:47:12
TD Ameritrade | Connecting. | 2019-05-06 14:47:15
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:15
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:15
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:15
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:15
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:15
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:15
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:16 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:16 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:16
TD Ameritrade | Disconnected. | 2019-05-06 14:47:16
Disconnected from TD Ameritrade. | 2019-05-06 14:47:16
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:16
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:16
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:16
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:16
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (1) | Closed. | 2019-05-06 14:47:16
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:16
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (2) | Closed. | 2019-05-06 14:47:16
TD Ameritrade | Connecting. | 2019-05-06 14:47:19
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:19
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:19
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:19
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:19
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:19
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:19
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:19
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:19
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (1) | Closed. | 2019-05-06 14:47:19
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:20 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:20 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:20
TD Ameritrade | Disconnected. | 2019-05-06 14:47:20
Disconnected from TD Ameritrade. | 2019-05-06 14:47:20
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:20
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:20
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:20
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (2) | Closed. | 2019-05-06 14:47:20
TD Ameritrade | Connecting. | 2019-05-06 14:47:23
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:23
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:23
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:23
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:23
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:23
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:23
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:24 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:24 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:24
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:24
TD Ameritrade | Disconnected. | 2019-05-06 14:47:24
Disconnected from TD Ameritrade. | 2019-05-06 14:47:24
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:24
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:24
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:24
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:24
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (1) | Closed. | 2019-05-06 14:47:24
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:24
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (2) | Closed. | 2019-05-06 14:47:24
TD Ameritrade | Connecting. | 2019-05-06 14:47:27
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:27
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:27
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:27
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:27
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:27
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:27
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:27 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:27 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:27
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:27
TD Ameritrade | Disconnected. | 2019-05-06 14:47:27
Disconnected from TD Ameritrade. | 2019-05-06 14:47:27
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:27
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:27
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:27
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:27
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (1) | Closed. | 2019-05-06 14:47:27
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:27
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (2) | Closed. | 2019-05-06 14:47:27
TD Ameritrade | Connecting. | 2019-05-06 14:47:30
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:30
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:30
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:30
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:30
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:30
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:30
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:31 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:31 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:31
TD Ameritrade | Disconnected. | 2019-05-06 14:47:31
Disconnected from TD Ameritrade. | 2019-05-06 14:47:31
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:31
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:31
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:31
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:31
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (2) | Closed. | 2019-05-06 14:47:31
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:31
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (1) | Closed. | 2019-05-06 14:47:31
TD Ameritrade | Connecting. | 2019-05-06 14:47:34
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:34
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:34
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:34
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:34
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:34
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:34
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:34 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:34 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:34
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:34
TD Ameritrade | Disconnected. | 2019-05-06 14:47:34
Disconnected from TD Ameritrade. | 2019-05-06 14:47:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:34
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:34
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:34
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:34
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (2) | Closed. | 2019-05-06 14:47:34
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:34
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (1) | Closed. | 2019-05-06 14:47:34
TD Ameritrade | Connecting. | 2019-05-06 14:47:37
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:37
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:37
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:37
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:37
HTTPS connection ID:28 to apis.tdameritrade.com:443 for request ID:28 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:37
HTTPS connection ID:28 to apis.tdameritrade.com:443 for request ID:28 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:37
File >> Disconnect selected. | 2019-05-06 14:47:37
TD Ameritrade | An HTTP request did not successfully complete. Request ID: 28. Requested script: StreamerInfo. | 2019-05-06 14:47:37 *
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:37
HTTPS connection ID:28 to apis.tdameritrade.com:443 for request ID:28 (2) | Closed. | 2019-05-06 14:47:37
TD Ameritrade | Disconnected. | 2019-05-06 14:47:37
Disconnected from TD Ameritrade. | 2019-05-06 14:47:37
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:37
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (1) | Closed. | 2019-05-06 14:47:37
TD Ameritrade | Connecting. | 2019-05-06 14:47:50
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:50
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:50
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:50
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:51
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:51
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:51
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:51 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:51 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:51
TD Ameritrade | Disconnected. | 2019-05-06 14:47:51
Disconnected from TD Ameritrade. | 2019-05-06 14:47:51
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:51
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:51
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:51
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:51
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (2) | Closed. | 2019-05-06 14:47:51
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:51
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (1) | Closed. | 2019-05-06 14:47:51
TD Ameritrade | Connecting. | 2019-05-06 14:47:54
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:54
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:54
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:54
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:54
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:54
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:54
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:54 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:54 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:54
TD Ameritrade | Disconnected. | 2019-05-06 14:47:54
Disconnected from TD Ameritrade. | 2019-05-06 14:47:54
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:54
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:54
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:54
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:54
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (1) | Closed. | 2019-05-06 14:47:54
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:54
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (2) | Closed. | 2019-05-06 14:47:54
TD Ameritrade | Connecting. | 2019-05-06 14:47:57
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:57
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:47:57
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:57
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:47:58
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:47:58
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:47:58
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:47:58 *
TD Ameritrade | Login failed. | 2019-05-06 14:47:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:47:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:58
TD Ameritrade | Disconnected. | 2019-05-06 14:47:58
Disconnected from TD Ameritrade. | 2019-05-06 14:47:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:47:58
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:58
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:47:58
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:47:58
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (1) | Closed. | 2019-05-06 14:47:58
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:47:58
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (2) | Closed. | 2019-05-06 14:47:58
File >> Disconnect selected. | 2019-05-06 14:47:59
TD Ameritrade | Disconnected. | 2019-05-06 14:47:59
Disconnected from TD Ameritrade. | 2019-05-06 14:47:59
TD Ameritrade | Connecting. | 2019-05-06 14:48:40
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:48:40
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:40
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:40
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:48:40
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:40
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:40
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:48:40 *
TD Ameritrade | Login failed. | 2019-05-06 14:48:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:48:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:40
TD Ameritrade | Disconnected. | 2019-05-06 14:48:40
Disconnected from TD Ameritrade. | 2019-05-06 14:48:40
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:40
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:40
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:40
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:48:40
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (1) | Closed. | 2019-05-06 14:48:40
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:48:40
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (2) | Closed. | 2019-05-06 14:48:40
TD Ameritrade | Connecting. | 2019-05-06 14:48:43
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:48:43
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:43
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:43
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:48:44
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:44
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:44
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:48:44 *
TD Ameritrade | Login failed. | 2019-05-06 14:48:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:48:44
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:44
TD Ameritrade | Disconnected. | 2019-05-06 14:48:44
Disconnected from TD Ameritrade. | 2019-05-06 14:48:44
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:44
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:44
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:44
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:48:44
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (1) | Closed. | 2019-05-06 14:48:44
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:48:44
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (2) | Closed. | 2019-05-06 14:48:44
TD Ameritrade | Connecting. | 2019-05-06 14:48:47
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:48:47
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:47
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:47
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:47
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:48:47
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:47
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:48:47 *
TD Ameritrade | Login failed. | 2019-05-06 14:48:47 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:48:47
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:47
TD Ameritrade | Disconnected. | 2019-05-06 14:48:47
Disconnected from TD Ameritrade. | 2019-05-06 14:48:47
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:47
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:47
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:47
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:48:47
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (1) | Closed. | 2019-05-06 14:48:47
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:48:47
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (2) | Closed. | 2019-05-06 14:48:47
TD Ameritrade | Connecting. | 2019-05-06 14:48:50
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:50
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:48:50
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:50
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:48:51
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:51
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:51
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:51
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:48:51
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (1) | Closed. | 2019-05-06 14:48:51
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:48:52 *
TD Ameritrade | Login failed. | 2019-05-06 14:48:52 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:48:52
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:52
TD Ameritrade | Disconnected. | 2019-05-06 14:48:52
Disconnected from TD Ameritrade. | 2019-05-06 14:48:52
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:52
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:52
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:48:52
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (2) | Closed. | 2019-05-06 14:48:52
TD Ameritrade | Connecting. | 2019-05-06 14:48:55
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:48:55
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:55
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:55
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:48:55
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:48:55
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:48:55
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:55
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:48:55
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (1) | Closed. | 2019-05-06 14:48:55
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:48:57 *
TD Ameritrade | Login failed. | 2019-05-06 14:48:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:48:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:57
TD Ameritrade | Disconnected. | 2019-05-06 14:48:57
Disconnected from TD Ameritrade. | 2019-05-06 14:48:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:48:57
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:48:57
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:48:57
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (2) | Closed. | 2019-05-06 14:48:57
TD Ameritrade | Connecting. | 2019-05-06 14:49:00
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:00
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:00
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:00
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:01
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:01
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:01
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:01 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:01 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:01
TD Ameritrade | Disconnected. | 2019-05-06 14:49:01
Disconnected from TD Ameritrade. | 2019-05-06 14:49:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:01
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:01
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:01
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:01
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (2) | Closed. | 2019-05-06 14:49:01
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:01
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (1) | Closed. | 2019-05-06 14:49:01
TD Ameritrade | Connecting. | 2019-05-06 14:49:04
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:04
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:04
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:04
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:04
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:04
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:04
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:04 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:04
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:04
TD Ameritrade | Disconnected. | 2019-05-06 14:49:04
Disconnected from TD Ameritrade. | 2019-05-06 14:49:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:04
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:04
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:04
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:04
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (2) | Closed. | 2019-05-06 14:49:04
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:04
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (1) | Closed. | 2019-05-06 14:49:04
TD Ameritrade | Connecting. | 2019-05-06 14:49:07
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:07
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:07
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:07
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:08
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:08
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:08
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:08 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:08 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:08
TD Ameritrade | Disconnected. | 2019-05-06 14:49:08
Disconnected from TD Ameritrade. | 2019-05-06 14:49:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:08
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:08
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:08
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:08
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (1) | Closed. | 2019-05-06 14:49:08
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:08
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (2) | Closed. | 2019-05-06 14:49:08
TD Ameritrade | Connecting. | 2019-05-06 14:49:11
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:11
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:11
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:11
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:11
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:11
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:11
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:11 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:11 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:11
TD Ameritrade | Disconnected. | 2019-05-06 14:49:11
Disconnected from TD Ameritrade. | 2019-05-06 14:49:11
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:11
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:11
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:11
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:11
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (2) | Closed. | 2019-05-06 14:49:11
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:11
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (1) | Closed. | 2019-05-06 14:49:11
TD Ameritrade | Connecting. | 2019-05-06 14:49:14
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:14
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:14
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:14
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:15
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:15
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:15
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:15 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:15 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:15
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:15
TD Ameritrade | Disconnected. | 2019-05-06 14:49:15
Disconnected from TD Ameritrade. | 2019-05-06 14:49:15
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:15
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:15
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:15
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:15
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (1) | Closed. | 2019-05-06 14:49:15
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:15
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (2) | Closed. | 2019-05-06 14:49:15
TD Ameritrade | Connecting. | 2019-05-06 14:49:18
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:18
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:18
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:18
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:18
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:18
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:18
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:18 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:18 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:18
TD Ameritrade | Disconnected. | 2019-05-06 14:49:18
Disconnected from TD Ameritrade. | 2019-05-06 14:49:18
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:18
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:18
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:18
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:18
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (1) | Closed. | 2019-05-06 14:49:18
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:18
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (2) | Closed. | 2019-05-06 14:49:18
TD Ameritrade | Connecting. | 2019-05-06 14:49:21
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:21
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:21
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:21
HTTPS connection ID:58 to apis.tdameritrade.com:443 for request ID:58 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:22
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:22
HTTPS connection ID:58 to apis.tdameritrade.com:443 for request ID:58 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:22
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:22 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:22
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:22
TD Ameritrade | Disconnected. | 2019-05-06 14:49:22
Disconnected from TD Ameritrade. | 2019-05-06 14:49:22
HTTPS connection ID:58 to apis.tdameritrade.com:443 for request ID:58 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:22
HTTPS connection ID:58 to apis.tdameritrade.com:443 for request ID:58 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:22
HTTPS connection ID:58 to apis.tdameritrade.com:443 for request ID:58 (2) | Closed. | 2019-05-06 14:49:22
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:22
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (1) | Closed. | 2019-05-06 14:49:22
TD Ameritrade | Connecting. | 2019-05-06 14:49:25
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:25
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:25
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:25
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:25
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:25
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:25
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:25 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:25 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:25
TD Ameritrade | Disconnected. | 2019-05-06 14:49:25
Disconnected from TD Ameritrade. | 2019-05-06 14:49:25
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:25
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:25
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:25
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:25
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (1) | Closed. | 2019-05-06 14:49:25
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:25
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (2) | Closed. | 2019-05-06 14:49:25
TD Ameritrade | Connecting. | 2019-05-06 14:49:28
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:28
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:28
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:28
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:29
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:29
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:29
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:29 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:29
TD Ameritrade | Disconnected. | 2019-05-06 14:49:29
Disconnected from TD Ameritrade. | 2019-05-06 14:49:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:29
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:29
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:29
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:29
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (1) | Closed. | 2019-05-06 14:49:29
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:29
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (2) | Closed. | 2019-05-06 14:49:29
TD Ameritrade | Connecting. | 2019-05-06 14:49:32
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:32
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:32
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:32
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:32
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:32
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:32
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:32 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:32 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:32
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:32
TD Ameritrade | Disconnected. | 2019-05-06 14:49:32
Disconnected from TD Ameritrade. | 2019-05-06 14:49:32
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:32
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:32
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:32
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:32
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (1) | Closed. | 2019-05-06 14:49:32
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:32
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (2) | Closed. | 2019-05-06 14:49:32
TD Ameritrade | Connecting. | 2019-05-06 14:49:35
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:35
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:35
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:35
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:36
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:36
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:36
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:36 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:36 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:36
TD Ameritrade | Disconnected. | 2019-05-06 14:49:36
Disconnected from TD Ameritrade. | 2019-05-06 14:49:36
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:36
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:36
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:36
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:36
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (2) | Closed. | 2019-05-06 14:49:36
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:36
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (1) | Closed. | 2019-05-06 14:49:36
TD Ameritrade | Connecting. | 2019-05-06 14:49:39
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:39
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:39
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:39
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:39
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:39
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:39
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:39 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:39
TD Ameritrade | Disconnected. | 2019-05-06 14:49:39
Disconnected from TD Ameritrade. | 2019-05-06 14:49:39
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:39
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:39
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:39
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:40
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (2) | Closed. | 2019-05-06 14:49:40
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:40
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (1) | Closed. | 2019-05-06 14:49:40
TD Ameritrade | Connecting. | 2019-05-06 14:49:42
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:42
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:42
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:42
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:43
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:43
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:43
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:43 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:43 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:43
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:43
TD Ameritrade | Disconnected. | 2019-05-06 14:49:43
Disconnected from TD Ameritrade. | 2019-05-06 14:49:43
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:43
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:43
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:43
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:43
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (2) | Closed. | 2019-05-06 14:49:43
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:43
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (1) | Closed. | 2019-05-06 14:49:43
TD Ameritrade | Connecting. | 2019-05-06 14:49:46
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:46
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:46
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:46
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:46
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:46
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:46
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:46 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:46
TD Ameritrade | Disconnected. | 2019-05-06 14:49:46
Disconnected from TD Ameritrade. | 2019-05-06 14:49:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:46
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:46
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:46
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:47
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Closed. | 2019-05-06 14:49:47
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:47
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (2) | Closed. | 2019-05-06 14:49:47
TD Ameritrade | Connecting. | 2019-05-06 14:49:49
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:49
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:49
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:49
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:50
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:50
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:50
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:50 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:50
TD Ameritrade | Disconnected. | 2019-05-06 14:49:50
Disconnected from TD Ameritrade. | 2019-05-06 14:49:50
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:50
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:50
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:50
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (2) | Closed. | 2019-05-06 14:49:50
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:50
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Closed. | 2019-05-06 14:49:50
TD Ameritrade | Connecting. | 2019-05-06 14:49:53
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:53
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:53
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:53
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:53
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:53
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:53
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:53 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:53 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:53
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:53
TD Ameritrade | Disconnected. | 2019-05-06 14:49:54
Disconnected from TD Ameritrade. | 2019-05-06 14:49:54
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:54
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:54
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:54
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:54
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (2) | Closed. | 2019-05-06 14:49:54
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:54
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Closed. | 2019-05-06 14:49:54
TD Ameritrade | Connecting. | 2019-05-06 14:49:57
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:49:57
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:57
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:57
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:49:57
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:49:57
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:49:57
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:49:57 *
TD Ameritrade | Login failed. | 2019-05-06 14:49:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:49:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:57
TD Ameritrade | Disconnected. | 2019-05-06 14:49:57
Disconnected from TD Ameritrade. | 2019-05-06 14:49:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:49:57
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:57
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:49:57
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:49:57
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Closed. | 2019-05-06 14:49:57
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:49:57
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (2) | Closed. | 2019-05-06 14:49:57
TD Ameritrade | Connecting. | 2019-05-06 14:50:00
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:00
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:00
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:00
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:00
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:00
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:00
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:01 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:01 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:01
TD Ameritrade | Disconnected. | 2019-05-06 14:50:01
Disconnected from TD Ameritrade. | 2019-05-06 14:50:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:01
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:01
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:01
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:01
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (2) | Closed. | 2019-05-06 14:50:01
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:01
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Closed. | 2019-05-06 14:50:01
TD Ameritrade | Connecting. | 2019-05-06 14:50:04
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:04
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:04
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:04
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:04
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:04
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:04
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:04 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:04
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:04
TD Ameritrade | Disconnected. | 2019-05-06 14:50:04
Disconnected from TD Ameritrade. | 2019-05-06 14:50:04
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:04
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:04
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:04
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Closed. | 2019-05-06 14:50:04
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:04
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (2) | Closed. | 2019-05-06 14:50:04
TD Ameritrade | Connecting. | 2019-05-06 14:50:07
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:07
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:07
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:07
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:07
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:07
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:07
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:08 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:08 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:08
TD Ameritrade | Disconnected. | 2019-05-06 14:50:08
Disconnected from TD Ameritrade. | 2019-05-06 14:50:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:08
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:08
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:08
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:08
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Closed. | 2019-05-06 14:50:08
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:08
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (2) | Closed. | 2019-05-06 14:50:08
TD Ameritrade | Connecting. | 2019-05-06 14:50:11
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:11
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:11
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:11
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:11
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:11
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:11
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:11
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:12
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Closed. | 2019-05-06 14:50:12
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:12 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:12
TD Ameritrade | Disconnected. | 2019-05-06 14:50:12
Disconnected from TD Ameritrade. | 2019-05-06 14:50:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:12
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:12
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:12
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (2) | Closed. | 2019-05-06 14:50:12
TD Ameritrade | Connecting. | 2019-05-06 14:50:15
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:15
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:15
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:15
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:18
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:18
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:18
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:18 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:18 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:18
TD Ameritrade | Disconnected. | 2019-05-06 14:50:18
Disconnected from TD Ameritrade. | 2019-05-06 14:50:18
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:18
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:18
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:18
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:18
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (1) | Closed. | 2019-05-06 14:50:18
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:18
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (2) | Closed. | 2019-05-06 14:50:18
TD Ameritrade | Connecting. | 2019-05-06 14:50:21
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:21
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:21
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:21
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:21
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:21
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:21
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:22
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:22 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:22
TD Ameritrade | Disconnected. | 2019-05-06 14:50:22
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:22
Disconnected from TD Ameritrade. | 2019-05-06 14:50:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:22
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:22
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Closed. | 2019-05-06 14:50:22
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:22
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (2) | Closed. | 2019-05-06 14:50:22
TD Ameritrade | Connecting. | 2019-05-06 14:50:25
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:25
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:25
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:25
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:25
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:25
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:25
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:25 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:25 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:25
TD Ameritrade | Disconnected. | 2019-05-06 14:50:25
Disconnected from TD Ameritrade. | 2019-05-06 14:50:25
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:25
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:25
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:25
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:25
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (2) | Closed. | 2019-05-06 14:50:25
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:25
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Closed. | 2019-05-06 14:50:25
TD Ameritrade | Connecting. | 2019-05-06 14:50:28
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:28
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:28
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:28
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:28
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:28
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:28
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:29 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:29
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:29
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:29
TD Ameritrade | Disconnected. | 2019-05-06 14:50:29
Disconnected from TD Ameritrade. | 2019-05-06 14:50:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:29
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:29
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Closed. | 2019-05-06 14:50:29
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:29
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (2) | Closed. | 2019-05-06 14:50:29
TD Ameritrade | Connecting. | 2019-05-06 14:50:32
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:32
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:32
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:32
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:32
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:32
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:32
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:32 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:32 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:32
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:32
TD Ameritrade | Disconnected. | 2019-05-06 14:50:32
Disconnected from TD Ameritrade. | 2019-05-06 14:50:32
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:32
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:32
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:32
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:32
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (2) | Closed. | 2019-05-06 14:50:32
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:32
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Closed. | 2019-05-06 14:50:32
TD Ameritrade | Connecting. | 2019-05-06 14:50:35
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:35
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:35
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:35
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:36
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:36
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:36
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:37 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:37 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:37
TD Ameritrade | Disconnected. | 2019-05-06 14:50:37
Disconnected from TD Ameritrade. | 2019-05-06 14:50:37
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:37
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:37
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:37
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:37
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Closed. | 2019-05-06 14:50:37
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:37
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (2) | Closed. | 2019-05-06 14:50:37
TD Ameritrade | Connecting. | 2019-05-06 14:50:40
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:40
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:40
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:40
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:40
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:40
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:40
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:40 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:40
TD Ameritrade | Disconnected. | 2019-05-06 14:50:40
Disconnected from TD Ameritrade. | 2019-05-06 14:50:40
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:40
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:40
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:40
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:40
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (2) | Closed. | 2019-05-06 14:50:40
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:40
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Closed. | 2019-05-06 14:50:40
TD Ameritrade | Connecting. | 2019-05-06 14:50:43
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:50:43
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:43
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:43
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:50:43
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:50:43
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:50:43
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:50:44 *
TD Ameritrade | Login failed. | 2019-05-06 14:50:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:50:44
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:44
TD Ameritrade | Disconnected. | 2019-05-06 14:50:44
Disconnected from TD Ameritrade. | 2019-05-06 14:50:44
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:50:44
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:44
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:50:44
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:50:44
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (2) | Closed. | 2019-05-06 14:50:44
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:50:44
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Closed. | 2019-05-06 14:50:44
File >> Disconnect selected. | 2019-05-06 14:50:45
TD Ameritrade | Disconnected. | 2019-05-06 14:50:45
Disconnected from TD Ameritrade. | 2019-05-06 14:50:45
TD Ameritrade | Connecting. | 2019-05-06 14:51:02
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:02
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:02
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:02
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:02
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:02
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:02
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:02 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:02 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:02
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:02
TD Ameritrade | Disconnected. | 2019-05-06 14:51:02
Disconnected from TD Ameritrade. | 2019-05-06 14:51:02
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:02
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:02
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:02
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:03
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (2) | Closed. | 2019-05-06 14:51:03
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:03
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Closed. | 2019-05-06 14:51:03
TD Ameritrade | Connecting. | 2019-05-06 14:51:05
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:05
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:05
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:05
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:09
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:09
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:09
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:09 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:09
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:09
TD Ameritrade | Disconnected. | 2019-05-06 14:51:09
Disconnected from TD Ameritrade. | 2019-05-06 14:51:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:09
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:09
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:09
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:09
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Closed. | 2019-05-06 14:51:09
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:09
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (2) | Closed. | 2019-05-06 14:51:09
TD Ameritrade | Connecting. | 2019-05-06 14:51:12
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:12
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:12
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:12
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:12
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:12
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:12
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:12 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:12
TD Ameritrade | Disconnected. | 2019-05-06 14:51:12
Disconnected from TD Ameritrade. | 2019-05-06 14:51:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:12
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:12
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:12
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:12
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Closed. | 2019-05-06 14:51:12
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:12
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (2) | Closed. | 2019-05-06 14:51:12
TD Ameritrade | Connecting. | 2019-05-06 14:51:15
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:15
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:15
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:15
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:19
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:19
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:19
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:19 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:19 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:19
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:19
TD Ameritrade | Disconnected. | 2019-05-06 14:51:19
Disconnected from TD Ameritrade. | 2019-05-06 14:51:19
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:19
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:19
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:19
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:19
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Closed. | 2019-05-06 14:51:19
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:19
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (2) | Closed. | 2019-05-06 14:51:19
TD Ameritrade | Connecting. | 2019-05-06 14:51:22
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:22
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:22
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:22
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:22
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:22
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:22
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:22 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:22
TD Ameritrade | Disconnected. | 2019-05-06 14:51:22
Disconnected from TD Ameritrade. | 2019-05-06 14:51:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:22
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:22
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:22
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:22
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (2) | Closed. | 2019-05-06 14:51:22
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:22
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Closed. | 2019-05-06 14:51:22
TD Ameritrade | Connecting. | 2019-05-06 14:51:25
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:25
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:25
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:25
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:26
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:26
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:26
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:26 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:26 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:26
TD Ameritrade | Disconnected. | 2019-05-06 14:51:26
Disconnected from TD Ameritrade. | 2019-05-06 14:51:26
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:26
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:26
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:26
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:26
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (2) | Closed. | 2019-05-06 14:51:26
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:26
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (1) | Closed. | 2019-05-06 14:51:26
TD Ameritrade | Connecting. | 2019-05-06 14:51:29
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:29
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:29
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:29
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:29
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:29
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:29
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:29 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:29
TD Ameritrade | Disconnected. | 2019-05-06 14:51:29
Disconnected from TD Ameritrade. | 2019-05-06 14:51:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:29
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:29
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:29
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:29
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (2) | Closed. | 2019-05-06 14:51:29
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:29
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (1) | Closed. | 2019-05-06 14:51:29
TD Ameritrade | Connecting. | 2019-05-06 14:51:32
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:32
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:32
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:32
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:33
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:33
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:33
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:33
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:33
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Closed. | 2019-05-06 14:51:33
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:33 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:33 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:33
TD Ameritrade | Disconnected. | 2019-05-06 14:51:33
Disconnected from TD Ameritrade. | 2019-05-06 14:51:33
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:33
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:33
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (2) | Closed. | 2019-05-06 14:51:33
TD Ameritrade | Connecting. | 2019-05-06 14:51:36
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:36
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:36
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:36
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:36
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:36
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:36
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:36 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:36 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:36
TD Ameritrade | Disconnected. | 2019-05-06 14:51:36
Disconnected from TD Ameritrade. | 2019-05-06 14:51:36
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:36
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:36
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:36
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:38
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (2) | Closed. | 2019-05-06 14:51:38
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:38
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (1) | Closed. | 2019-05-06 14:51:38
TD Ameritrade | Connecting. | 2019-05-06 14:51:39
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:39
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:39
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:39
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:40
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:40
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:40
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:40 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:40
TD Ameritrade | Disconnected. | 2019-05-06 14:51:40
Disconnected from TD Ameritrade. | 2019-05-06 14:51:40
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:40
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:40
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:40
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:40
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Closed. | 2019-05-06 14:51:40
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:40
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (2) | Closed. | 2019-05-06 14:51:40
TD Ameritrade | Connecting. | 2019-05-06 14:51:43
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:43
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:43
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:43
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:43
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:43
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:43
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:43 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:43 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:43
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:43
TD Ameritrade | Disconnected. | 2019-05-06 14:51:43
Disconnected from TD Ameritrade. | 2019-05-06 14:51:43
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:43
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:43
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:43
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:43
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Closed. | 2019-05-06 14:51:43
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:43
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (2) | Closed. | 2019-05-06 14:51:43
TD Ameritrade | Connecting. | 2019-05-06 14:51:46
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:46
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:46
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:46
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:47
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:47
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:47
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:47 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:47 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:47
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:47
TD Ameritrade | Disconnected. | 2019-05-06 14:51:47
Disconnected from TD Ameritrade. | 2019-05-06 14:51:47
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:47
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:47
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:47
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:47
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Closed. | 2019-05-06 14:51:47
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:47
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (2) | Closed. | 2019-05-06 14:51:47
The message log has been sent to support. | 2019-05-06 14:51:48 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:48
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-05-06 14:51:48
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2019-05-06 14:51:49
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:49
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:49
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-05-06 14:51:49
TD Ameritrade | Connecting. | 2019-05-06 14:51:50
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:50
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:50
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:50
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:50
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:50
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:50
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:50 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:50
TD Ameritrade | Disconnected. | 2019-05-06 14:51:50
Disconnected from TD Ameritrade. | 2019-05-06 14:51:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:50
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:50
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:50
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:50
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (2) | Closed. | 2019-05-06 14:51:50
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:50
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Closed. | 2019-05-06 14:51:50
TD Ameritrade | Connecting. | 2019-05-06 14:51:53
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:53
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:53
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:53
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:54
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:54
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:54
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:54 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:54 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:54
TD Ameritrade | Disconnected. | 2019-05-06 14:51:54
Disconnected from TD Ameritrade. | 2019-05-06 14:51:54
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:54
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:54
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:54
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:54
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Closed. | 2019-05-06 14:51:54
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:54
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (2) | Closed. | 2019-05-06 14:51:54
TD Ameritrade | Connecting. | 2019-05-06 14:51:57
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:51:57
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:57
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:57
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:51:57
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:51:57
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:51:57
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:51:57 *
TD Ameritrade | Login failed. | 2019-05-06 14:51:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:51:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:57
TD Ameritrade | Disconnected. | 2019-05-06 14:51:57
Disconnected from TD Ameritrade. | 2019-05-06 14:51:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:51:57
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:57
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:51:57
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:51:57
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (2) | Closed. | 2019-05-06 14:51:57
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:51:57
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Closed. | 2019-05-06 14:51:57
TD Ameritrade | Connecting. | 2019-05-06 14:52:00
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:00
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:00
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:00
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:01
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:01
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:01
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:01 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:01 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:01
TD Ameritrade | Disconnected. | 2019-05-06 14:52:01
Disconnected from TD Ameritrade. | 2019-05-06 14:52:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:01
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:01
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:01
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:01
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (2) | Closed. | 2019-05-06 14:52:01
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:01
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Closed. | 2019-05-06 14:52:01
TD Ameritrade | Connecting. | 2019-05-06 14:52:04
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:04
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:04
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:04
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:04
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:04
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:04
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:04 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:04
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:04
TD Ameritrade | Disconnected. | 2019-05-06 14:52:04
Disconnected from TD Ameritrade. | 2019-05-06 14:52:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:04
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:04
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:04
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:04
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Closed. | 2019-05-06 14:52:04
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:04
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (2) | Closed. | 2019-05-06 14:52:04
TD Ameritrade | Connecting. | 2019-05-06 14:52:07
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:07
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:07
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:07
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:08
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:08
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:08
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:08 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:08 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:08
TD Ameritrade | Disconnected. | 2019-05-06 14:52:08
Disconnected from TD Ameritrade. | 2019-05-06 14:52:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:08
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:08
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:08
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:08
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Closed. | 2019-05-06 14:52:08
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:08
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (2) | Closed. | 2019-05-06 14:52:08
TD Ameritrade | Connecting. | 2019-05-06 14:52:11
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:11
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:11
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:11
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:11
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:11
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:11
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:11 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:11 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:11
TD Ameritrade | Disconnected. | 2019-05-06 14:52:11
Disconnected from TD Ameritrade. | 2019-05-06 14:52:11
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:11
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:11
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:11
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:11
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (2) | Closed. | 2019-05-06 14:52:11
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:11
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Closed. | 2019-05-06 14:52:11
TD Ameritrade | Connecting. | 2019-05-06 14:52:14
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:14
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:14
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:14
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:15
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:15
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:15
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:15 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:15 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:15
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:15
TD Ameritrade | Disconnected. | 2019-05-06 14:52:15
Disconnected from TD Ameritrade. | 2019-05-06 14:52:15
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:15
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:15
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:15
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:15
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Closed. | 2019-05-06 14:52:15
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:15
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (2) | Closed. | 2019-05-06 14:52:15
TD Ameritrade | Connecting. | 2019-05-06 14:52:18
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:18
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:18
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:18
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:18
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:18
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:18
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:18 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:18 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:18
TD Ameritrade | Disconnected. | 2019-05-06 14:52:18
Disconnected from TD Ameritrade. | 2019-05-06 14:52:18
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:18
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:18
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:18
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:18
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Closed. | 2019-05-06 14:52:18
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:18
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (2) | Closed. | 2019-05-06 14:52:18
TD Ameritrade | Connecting. | 2019-05-06 14:52:21
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:21
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:21
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:21
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:22
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:22
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:22
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:22 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:22
TD Ameritrade | Disconnected. | 2019-05-06 14:52:22
Disconnected from TD Ameritrade. | 2019-05-06 14:52:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:22
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:22
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:22
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:22
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Closed. | 2019-05-06 14:52:22
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:22
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (2) | Closed. | 2019-05-06 14:52:22
TD Ameritrade | Connecting. | 2019-05-06 14:52:25
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:25
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:25
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:25
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:25
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:25
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:25
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:25 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:25 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:25
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:25
TD Ameritrade | Disconnected. | 2019-05-06 14:52:25
Disconnected from TD Ameritrade. | 2019-05-06 14:52:25
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:25
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:25
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:25
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Closed. | 2019-05-06 14:52:25
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:25
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (2) | Closed. | 2019-05-06 14:52:25
TD Ameritrade | Connecting. | 2019-05-06 14:52:28
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:28
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:28
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:28
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:29
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:29
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:29
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:29 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:29
TD Ameritrade | Disconnected. | 2019-05-06 14:52:29
Disconnected from TD Ameritrade. | 2019-05-06 14:52:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:29
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:29
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:29
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:29
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (2) | Closed. | 2019-05-06 14:52:29
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:29
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Closed. | 2019-05-06 14:52:29
TD Ameritrade | Connecting. | 2019-05-06 14:52:32
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:32
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:32
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:32
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:32
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:32
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:32
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:32 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:32 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:32
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:32
TD Ameritrade | Disconnected. | 2019-05-06 14:52:32
Disconnected from TD Ameritrade. | 2019-05-06 14:52:32
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:32
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:32
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:32
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:32
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Closed. | 2019-05-06 14:52:32
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:32
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (2) | Closed. | 2019-05-06 14:52:32
TD Ameritrade | Connecting. | 2019-05-06 14:52:35
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:35
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:35
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:35
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:36
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:36
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:36
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:36 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:36 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:36
TD Ameritrade | Disconnected. | 2019-05-06 14:52:36
Disconnected from TD Ameritrade. | 2019-05-06 14:52:36
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:36
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:36
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:36
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:36
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (2) | Closed. | 2019-05-06 14:52:36
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:36
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Closed. | 2019-05-06 14:52:36
TD Ameritrade | Connecting. | 2019-05-06 14:52:39
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:39
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:39
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:39
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:39
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:39
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:39
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:39 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:39
TD Ameritrade | Disconnected. | 2019-05-06 14:52:39
Disconnected from TD Ameritrade. | 2019-05-06 14:52:39
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:39
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:39
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:39
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:40
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Closed. | 2019-05-06 14:52:40
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:40
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (2) | Closed. | 2019-05-06 14:52:40
TD Ameritrade | Connecting. | 2019-05-06 14:52:42
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:42
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:42
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:42
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:43
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:43
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:43
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:43 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:43 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:43
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:43
TD Ameritrade | Disconnected. | 2019-05-06 14:52:43
Disconnected from TD Ameritrade. | 2019-05-06 14:52:43
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:43
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:43
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:43
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:43
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (2) | Closed. | 2019-05-06 14:52:43
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:43
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Closed. | 2019-05-06 14:52:43
TD Ameritrade | Connecting. | 2019-05-06 14:52:46
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:46
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:46
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:46
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:46
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:46
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:46
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:46 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:46
TD Ameritrade | Disconnected. | 2019-05-06 14:52:46
Disconnected from TD Ameritrade. | 2019-05-06 14:52:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:46
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:46
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:46
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:46
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (2) | Closed. | 2019-05-06 14:52:46
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:46
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (1) | Closed. | 2019-05-06 14:52:46
TD Ameritrade | Connecting. | 2019-05-06 14:52:49
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:49
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:49
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:49
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:50
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:50
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:50
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:50 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:50
TD Ameritrade | Disconnected. | 2019-05-06 14:52:50
Disconnected from TD Ameritrade. | 2019-05-06 14:52:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:50
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:50
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:50
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:50
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Closed. | 2019-05-06 14:52:50
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:50
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (2) | Closed. | 2019-05-06 14:52:50
TD Ameritrade | Connecting. | 2019-05-06 14:52:53
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:53
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:53
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:53
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:53
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:53
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:53
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:53 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:53 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:53
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:53
TD Ameritrade | Disconnected. | 2019-05-06 14:52:53
Disconnected from TD Ameritrade. | 2019-05-06 14:52:53
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:53
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:53
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:53
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:54
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (2) | Closed. | 2019-05-06 14:52:54
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:54
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Closed. | 2019-05-06 14:52:54
TD Ameritrade | Connecting. | 2019-05-06 14:52:56
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:52:56
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:56
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:56
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:52:57
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:52:57
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:52:57
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:52:57 *
TD Ameritrade | Login failed. | 2019-05-06 14:52:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:52:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:57
TD Ameritrade | Disconnected. | 2019-05-06 14:52:57
Disconnected from TD Ameritrade. | 2019-05-06 14:52:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:52:57
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:57
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:52:57
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:52:57
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (1) | Closed. | 2019-05-06 14:52:57
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:52:57
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (2) | Closed. | 2019-05-06 14:52:57
TD Ameritrade | Connecting. | 2019-05-06 14:53:00
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:00
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:00
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:00
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:00
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:00
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:00
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:00 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:00 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:00
TD Ameritrade | Disconnected. | 2019-05-06 14:53:00
Disconnected from TD Ameritrade. | 2019-05-06 14:53:00
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:00
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:00
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:00
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:01
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (2) | Closed. | 2019-05-06 14:53:01
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:01
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (1) | Closed. | 2019-05-06 14:53:01
TD Ameritrade | Connecting. | 2019-05-06 14:53:03
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:03
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:03
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:03
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:04
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:04
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:04
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:04 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:04
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:04
TD Ameritrade | Disconnected. | 2019-05-06 14:53:04
Disconnected from TD Ameritrade. | 2019-05-06 14:53:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:04
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:04
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:04
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:04
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (1) | Closed. | 2019-05-06 14:53:04
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:04
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (2) | Closed. | 2019-05-06 14:53:04
TD Ameritrade | Connecting. | 2019-05-06 14:53:07
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:07
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:07
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:07
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:07
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:07
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:07
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:08 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:08 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:08
TD Ameritrade | Disconnected. | 2019-05-06 14:53:08
Disconnected from TD Ameritrade. | 2019-05-06 14:53:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:08
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:08
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:08
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:08
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (1) | Closed. | 2019-05-06 14:53:08
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:08
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (2) | Closed. | 2019-05-06 14:53:08
TD Ameritrade | Connecting. | 2019-05-06 14:53:11
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:11
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:11
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:11
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:12
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:12
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:12
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:12 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:12
TD Ameritrade | Disconnected. | 2019-05-06 14:53:12
Disconnected from TD Ameritrade. | 2019-05-06 14:53:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:12
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:12
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:12
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:12
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (2) | Closed. | 2019-05-06 14:53:12
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:12
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Closed. | 2019-05-06 14:53:12
TD Ameritrade | Connecting. | 2019-05-06 14:53:15
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:15
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:15
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:15
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:16
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:16
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:16
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:16
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:16
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Closed. | 2019-05-06 14:53:16
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:19 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:19 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:19
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:19
TD Ameritrade | Disconnected. | 2019-05-06 14:53:19
Disconnected from TD Ameritrade. | 2019-05-06 14:53:19
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:19
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:19
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:19
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (2) | Closed. | 2019-05-06 14:53:19
TD Ameritrade | Connecting. | 2019-05-06 14:53:22
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:22
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:22
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:22
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:22
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:22
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:22
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:22 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:22
TD Ameritrade | Disconnected. | 2019-05-06 14:53:22
Disconnected from TD Ameritrade. | 2019-05-06 14:53:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:22
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:22
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:22
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:22
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (2) | Closed. | 2019-05-06 14:53:22
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:22
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Closed. | 2019-05-06 14:53:22
TD Ameritrade | Connecting. | 2019-05-06 14:53:25
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:25
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:25
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:25
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:26
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:26
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:26
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:26 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:26 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:26
TD Ameritrade | Disconnected. | 2019-05-06 14:53:26
Disconnected from TD Ameritrade. | 2019-05-06 14:53:26
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:26
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:26
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:26
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:26
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Closed. | 2019-05-06 14:53:26
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:26
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (2) | Closed. | 2019-05-06 14:53:26
TD Ameritrade | Connecting. | 2019-05-06 14:53:29
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:29
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:29
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:29
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:29
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:29
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:29
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:29 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:29
TD Ameritrade | Disconnected. | 2019-05-06 14:53:29
Disconnected from TD Ameritrade. | 2019-05-06 14:53:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:29
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:29
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:29
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:29
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Closed. | 2019-05-06 14:53:29
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:29
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (2) | Closed. | 2019-05-06 14:53:29
TD Ameritrade | Connecting. | 2019-05-06 14:53:32
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:32
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:32
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:32
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:33
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:33
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:33
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:33 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:33 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:33
TD Ameritrade | Disconnected. | 2019-05-06 14:53:33
Disconnected from TD Ameritrade. | 2019-05-06 14:53:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:33
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:33
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:33
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:33
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (2) | Closed. | 2019-05-06 14:53:33
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:33
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Closed. | 2019-05-06 14:53:33
TD Ameritrade | Connecting. | 2019-05-06 14:53:36
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:36
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:36
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:36
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:36
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:36
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:36
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:37 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:37 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:37
TD Ameritrade | Disconnected. | 2019-05-06 14:53:37
Disconnected from TD Ameritrade. | 2019-05-06 14:53:37
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:37
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:37
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:37
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:37
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (2) | Closed. | 2019-05-06 14:53:37
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:37
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Closed. | 2019-05-06 14:53:37
TD Ameritrade | Connecting. | 2019-05-06 14:53:40
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:40
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:40
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:40
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:40
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:40
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:40
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:40 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:40
TD Ameritrade | Disconnected. | 2019-05-06 14:53:40
Disconnected from TD Ameritrade. | 2019-05-06 14:53:40
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:40
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:40
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:40
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:40
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Closed. | 2019-05-06 14:53:40
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:40
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (2) | Closed. | 2019-05-06 14:53:40
TD Ameritrade | Connecting. | 2019-05-06 14:53:43
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:43
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:43
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:43
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:43
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:43
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:43
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:44 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:44
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:44
TD Ameritrade | Disconnected. | 2019-05-06 14:53:44
Disconnected from TD Ameritrade. | 2019-05-06 14:53:44
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:44
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:44
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:44
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:44
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Closed. | 2019-05-06 14:53:44
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:44
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (2) | Closed. | 2019-05-06 14:53:44
TD Ameritrade | Connecting. | 2019-05-06 14:53:47
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:47
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:47
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:47
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:47
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:47
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:47
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:47 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:47 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:47
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:47
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:47
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:47
TD Ameritrade | Disconnected. | 2019-05-06 14:53:47
Disconnected from TD Ameritrade. | 2019-05-06 14:53:47
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:47
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:47
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Closed. | 2019-05-06 14:53:47
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:47
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (2) | Closed. | 2019-05-06 14:53:47
TD Ameritrade | Connecting. | 2019-05-06 14:53:50
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:50
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:50
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:50
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:50
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:50
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:50
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:50 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:50
TD Ameritrade | Disconnected. | 2019-05-06 14:53:51
Disconnected from TD Ameritrade. | 2019-05-06 14:53:51
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:51
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:51
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:51
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:51
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (2) | Closed. | 2019-05-06 14:53:51
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:51
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Closed. | 2019-05-06 14:53:51
TD Ameritrade | Connecting. | 2019-05-06 14:53:54
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:54
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:54
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:54
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:54
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:54
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:54
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:54 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:54 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:54
TD Ameritrade | Disconnected. | 2019-05-06 14:53:54
Disconnected from TD Ameritrade. | 2019-05-06 14:53:54
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:54
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:54
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:54
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:54
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Closed. | 2019-05-06 14:53:54
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:54
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (2) | Closed. | 2019-05-06 14:53:54
TD Ameritrade | Connecting. | 2019-05-06 14:53:57
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:53:57
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:57
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:57
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:53:57
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:53:57
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:53:57
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:53:58 *
TD Ameritrade | Login failed. | 2019-05-06 14:53:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:53:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:58
TD Ameritrade | Disconnected. | 2019-05-06 14:53:58
Disconnected from TD Ameritrade. | 2019-05-06 14:53:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:53:58
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:58
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:53:58
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:53:58
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Closed. | 2019-05-06 14:53:58
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:53:58
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (2) | Closed. | 2019-05-06 14:53:58
TD Ameritrade | Connecting. | 2019-05-06 14:54:01
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:54:01
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:54:01
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:54:01
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:54:01
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:54:01
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:54:01
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:54:01 *
TD Ameritrade | Login failed. | 2019-05-06 14:54:01 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:54:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:54:01
TD Ameritrade | Disconnected. | 2019-05-06 14:54:01
Disconnected from TD Ameritrade. | 2019-05-06 14:54:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:54:01
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:54:01
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:54:01
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:54:01
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (2) | Closed. | 2019-05-06 14:54:01
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:54:01
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Closed. | 2019-05-06 14:54:01
TD Ameritrade | Connecting. | 2019-05-06 14:54:04
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:54:04
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:54:04
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:54:04
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:54:04
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:54:04
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:54:04
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:54:04 *
TD Ameritrade | Login failed. | 2019-05-06 14:54:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:54:04
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:54:04
TD Ameritrade | Disconnected. | 2019-05-06 14:54:04
Disconnected from TD Ameritrade. | 2019-05-06 14:54:04
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:54:04
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:54:04
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:54:04
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:54:05
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Closed. | 2019-05-06 14:54:05
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:54:05
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (2) | Closed. | 2019-05-06 14:54:05
TD Ameritrade | Connecting. | 2019-05-06 14:56:04
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-05-06 14:56:04
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Creating socket. Using TLS 1.2. | 2019-05-06 14:56:04
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:56:04
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-05-06 14:56:05
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (2) | Creating socket. Using TLS 1.2. | 2019-05-06 14:56:05
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (2) | Connecting to IP: 198.200.171.201. | 2019-05-06 14:56:05
TD Ameritrade | Server error while trying to get the streamer info. Error: NS Error message: User is not allowed to access Streamer. | 2019-05-06 14:56:05 *
TD Ameritrade | Login failed. | 2019-05-06 14:56:05 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-05-06 14:56:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:56:05
TD Ameritrade | Disconnected. | 2019-05-06 14:56:05
Disconnected from TD Ameritrade. | 2019-05-06 14:56:05
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-05-06 14:56:05
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:56:05
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (2) | Shutdown started. Waiting for graceful close. | 2019-05-06 14:56:05
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (2) | Socket gracefully closed by remote side. | 2019-05-06 14:56:05
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (2) | Closed. | 2019-05-06 14:56:05
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Socket gracefully closed by remote side. | 2019-05-06 14:56:05
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Closed. | 2019-05-06 14:56:05
[2019-05-06 17:13:35]
Sierra Chart - Max - Posts: 5780
1. You are getting the following error TD Ameritrade:
Contact TD Ameritrade about your account and have them authorize the "Streamer" for the TD Ameritrade Web API.
2. What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
If you require real-time futures data, then refer to:
https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php
Sierra Chart Support
Date Time Of Last Edit: 2019-05-06 17:14:11
