Date/Time: Fri, 31 Jan 2025 10:58:11 +0000
"Reset recent Bid/Ask Volume on Bid/Ask Change" not working
View Count: 1304
[2019-05-06 14:48:17] |
User884307 - Posts: 173 |
The title explains situation which is set from ChartDOM settings in the DOM V1910 thro v1916 not working as I have tried them. Cheers PS. I am simply advising you of this problem as a customer, please dont give me an unfriendly response, Ta! :-)x |
[2019-05-06 20:16:53] |
This is an area that has had a lot of work lately, and others have verified that in the most recent version it is working correctly. Be aware that the Recent Bid Ask Volume Timeout in Milliseconds applies when this setting is enabled, so if this is non-zero, then the Recent Bid/Ask may not immediately change. Refer to the following: Global Trade Settings Windows: Reset Recent Bid/Ask Volume on Bid/Ask Change (Global Settings >> Chart DOM Settings >> Other >> Other Settings) If you still feel it is not working properly, then we would need additional information to know what you believe the problem is. But it is really very unlikely this is the case because after the work done, users who have previously pointed out resetting issues now say it is working properly as expected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
