Date/Time: Fri, 31 Jan 2025 12:11:06 +0000
Regarding getting win rate in excel while doing back testing in sierra
View Count: 870
[2019-05-06 12:11:31] |
User479048 - Posts: 19 |
Hi, I wanted to know if while doing back testing can i receive Win Rate and Profit Rate in excel according to the Time Frame selected. For Eg: https://prnt.sc/nkybaz when you open the above screenshot i want to generate in excel these yellow cells |
[2019-05-07 15:24:01] |
Have a look at the Trade Statistics that Sierra Chart provides through the Trade Statistics tab: Trade Activity Log: Trade Statistics Tab You can save the data from that tab in a text format and look at it in Excel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
