Date/Time: Fri, 31 Jan 2025 10:41:37 +0000
[Programming Help] - Create a Study
View Count: 892
[2019-05-05 22:46:52]
User778720 - Posts: 1
Support,
I would like to be able to automatically high lite or make another color an engulfing candlestick bar that has engulfed 2 or more of the previous candle stick bars. Is this possible and how much would you charge to code that.
Thanks, Jeff
[2019-05-06 07:46:11]
@sstfrederik - Posts: 405
Hi Jeff,
Stumbled on yr post. You can do what you want with simple alert conditions and the study called "Color Bar based on alert condition". Very powerful study.
See attached chartbook as an example. You can adjust the alert conditions as needed.
Color Bar Based on Alert Condition
Frederik
https://www.simplesystemtrading.com/
attachmentChartbook16.Cht - Attached On 2019-05-06 07:42:22 UTC - Size: 39.31 KB - 419 views
