Date/Time: Fri, 31 Jan 2025 10:47:51 +0000
Limit chase function for stop limit orders
View Count: 752
[2019-05-05 21:35:47] |
user8222 - Posts: 21 |
Hi, is it possible to have stop limit orders initiate a limit chase once triggered? I.e. stop BTC at 6000, stop limit buy at 5999.5, chase X ticks?
[2019-05-07 04:03:52] |
This would require custom programming.
