Date/Time: Sat, 19 Sep 2026 21:23:47 +0000
GDT_NUMERIC_INFORMATION GraphDrawType
View Count: 1698
| [2019-05-05 20:11:47] |
| User420296 - Posts: 12 |
I am using this draw type to show a character string that represents different attributes. For instance, number 1 for attribute 1, number 2 for attribute 2. I would like to show number 1 red and number 2 green in the table. Is this possible? Think I should add here that I'd like the attribute (12) to be in one cell in the table. |
| [2019-05-05 23:13:45] |
| Kiwi - Posts: 375 |
On this page ACSIL Interface Members - sc.Subgraph Array under sc.Subgraph[].DataColor[] it discusses changing foreground & background colours for GDT_NUMERIC_INFORMATION |
| [2019-05-07 04:09:44] |
Let us know if post #2 answered your question and if you need any further help. One cell can only be one color. Although it is also possible to control the background color.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-07 04:11:08
| [2019-05-07 11:40:12] |
Yes my question was answered, thanks for the follow up.
| [2019-08-11 04:39:05] |
Sometimes the cells in the GDT_NUMERIC_INFORMATION table are not being colored and I'm forced to do a manual recalculate periodically. This does not always happen just sometimes and it "seems" that it "might" be due to high market volatility when it occurs. Can you think of anything I can do, other than manual recalculation, to correct this? I have followed the scsf_NumericInformationGraphDrawTypeExample example. Thanks.
| [2019-08-11 23:36:36] |
Sometimes the cells in the GDT_NUMERIC_INFORMATION table are not being colored and I'm forced to do a manual recalculate periodically. This sounds like a problem with your study function code itself. Possibly related to study calculation order. Refer to:Chart Studies: Study Calculation Precedence And Related Issues Otherwise, there should never be a problem with numeric information table coloring. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-11 23:36:47
| [2019-08-11 23:45:58] |
"Otherwise, there should never be a problem with numeric information table coloring." This is what i needed to hear thanks, usually I can fix my mistakes :) |
