Date/Time: Fri, 31 Jan 2025 11:46:45 +0000
Can you please add ACSIl two timeframe additive study
View Count: 767
[2019-05-05 19:48:41]
ertrader - Posts: 681
Hi support,
Can you please add the ACSIL in the User Contributed Advanced Custom Study System Source Code for the two timeframe trend additive study?
I've checked there and in both the UserContributedStudies2.cpp and UserContributedStudies.cpp files.
[2019-05-08 01:44:32]
Is this study ACSIL available?
[2019-05-08 19:03:52]
The code is old and poorly formatted. It was not developed by us:
SCSFExport scsf_2TrendAdd(SCStudyInterfaceRef sc)
  SCSubgraphRef   EnterNow = sc.Subgraph[0], LTF = sc.Subgraph[1], TF = sc.Subgraph[2], R1 = sc.Subgraph[3],
          se5 = sc.Subgraph[12], se12 = sc.Subgraph[13], sr = sc.Subgraph[14], xe5 = sc.Subgraph[15], xe12 = sc.Subgraph[16], xr = sc.Subgraph[17],
          lc = sc.Subgraph[20], le5 = sc.Subgraph[21], le12 = sc.Subgraph[22], lr = sc.Subgraph[23],  ple5 = sc.Subgraph[24], ple12 = sc.Subgraph[25], plr = sc.Subgraph[26];
  if (sc.SetDefaults)
    sc.GraphName="Two Timeframe Trend Additive";
    EnterNow.Name="EnterNow";  LTF.Name="LTF";    TF.Name="TF";  R1.Name="R1";
    se5.Name="se5";    se12.Name="se12";  sr.Name="sr";    xe5.Name="se5";    xe12.Name="se12";  xr.Name="sr";
    lc.Name="lc";    le5.Name="le5";    le12.Name="le12";  lr.Name="lr";  ple5.Name="ple5";    ple12.Name="ple12";  plr.Name="plr";
    sc.CalculationPrecedence = STD_PREC_LEVEL ;    sc.DrawZeros=0;    return;
    This takes the trend from 5m and 30m using rsi>50 and ema1>ema2 for +ve
    When both trends are in the same direciton positive trend exists and price/value signals can be taken
    So it is the addition of 2 trends
  int   i,p,p2,lp,hour,minute,second, minute2, as=sc.ArraySize-1, ST_Direction;
  int& li = sc.PersistVars->i1; int& offset = sc.PersistVars->i2;  int& lastshifted = sc.PersistVars->i3;
  int& lastdot = sc.PersistVars->i4; float& LT_Direction = sc.PersistVars->f1;
  if(sc.UpdateStartIndex==0) { li=0; offset=5; lastshifted=0; LT_Direction=0; ST_Direction=0; }
  for (i=sc.UpdateStartIndex; i < sc.ArraySize; i++)
    p=i-1; lp=li-1; p2=i-2;
    sc.BaseDateTimeIn[i-1].GetTimeHMS(hour, minute, second); sc.BaseDateTimeIn[i].GetTimeHMS(hour, minute2, second);
    if( (minute2 % 30)==0 || (((minute+5) % 30)==0 && (minute2 % 30)!=0) ) { //|| (fmod(minute+5,30)==0 && fmod(minute2,30)!=0)
      lc[li]=sc.BaseDataIn[SC_LAST][p];
      sc.MovingAverage(lc, le5, MOVAVGTYPE_EXPONENTIAL, li, 5 );
      sc.MovingAverage(lc, le12, MOVAVGTYPE_EXPONENTIAL, li, 12);
      sc.RSI(lc, lr, li, MOVAVGTYPE_SIMPLE, 20);
      if(lr[li]>50 && (le5[li]>le12[li] || (le5[li]==le12[li] && le5[lp]>le12[lp]))) LT_Direction=+1; else
      if(lr[li]<50 && (le5[li]<le12[li] || (le5[li]==le12[li] && le5[lp]<le12[lp]))) LT_Direction=-1; else
        LT_Direction=0;
      if(i<as) li++;
    LTF[i]=LT_Direction/1.1;
    sc.MovingAverage(sc.BaseDataIn[SC_LAST], se5, MOVAVGTYPE_EXPONENTIAL, i, 5 );
    sc.MovingAverage(sc.BaseDataIn[SC_LAST], se12, MOVAVGTYPE_EXPONENTIAL, i, 12);
    sc.RSI(sc.BaseDataIn[SC_LAST], sr, i, MOVAVGTYPE_SIMPLE, 20);
    if(sr[p]>50 && (se5[p]>se12[p] || (se5[p]==se12[p] && se5[p2]>se12[p2]))) TF[i]=+0.8; else
    if(sr[p]<50 && (se5[p]<se12[p] || (se5[p]==se12[p] && se5[p2]<se12[p2]))) TF[i]=-0.8; else
      TF[i]=0;
    EnterNow[i]=0;
  //  if( sc.BaseDateTimeIn[i].GetTimeInSeconds()>=HMS_TIME(10,00,00) && sc.BaseDateTimeIn[i].GetTimeInSeconds()<=HMS_TIME(12,00,00) ) {
      if(LTF[i]>0 && TF[i]>0) EnterNow[i]=.6; else
        if(LTF[i]<0 && TF[i]<0) EnterNow[i]=-.6;
