Date/Time: Sun, 09 Feb 2025 04:23:19 +0000
Copying Chart Drawings
View Count: 1241
[2019-05-04 23:19:05] |
User116783 - Posts: 84 |
Hi, Is there a way to copy just drawings but not anything else from one chart to another? For example, just copying lines from the 4 hour chart to the 5 min chart. But not copying text. Thanks, ZS Date Time Of Last Edit: 2019-05-04 23:20:14
[2020-08-08 18:18:33] |
TLS - Posts: 1 |
I too would like to know if there's an option like this. I make notations and drawings on my main trading chart and would like my drawings to transfer to other reference charts, but not the notations. On higher, zoomed out time-frames, my notes clutter up the page. If I try hiding them on a reference chart it hides them on my main chart. Thanks! |
[2020-08-09 20:03:55] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2020-08-10 18:14:16] |
User414533 - Posts: 106 |
Done. |
[2020-08-10 18:40:16] |
There is a way to prevent specific drawings from being copied: Copying Chart Drawings from Other Charts Automatically: Preventing Specific Chart Drawings from Being Copied Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
