Date/Time: Fri, 29 Mar 2024 14:39:08 +0000
CME Stock Index Micro Future Contracts
View Count: 2081
[2019-05-04 19:05:53] |
We have added the symbols settings for the new CME micro contracts for the major stock indices. To receive the updated settings, follow the instructions here: Global Symbol Settings: Update Symbol Settings Also, Friday evening when we released the settings for CQG, there was an error in the XML data which the settings are encoded using, preventing any user who updated at or after that time, from not actually getting those settings. This has now been corrected. So if you are using CQG, you need to update the symbol settings again as explained here: Global Symbol Settings: Update Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-06 16:41:20] |
Hopeman - Posts: 156 |
Hello !!! atually i have CME E-mini, For professionals and users without a trading account, for E-micro what do I need?
[2019-05-06 19:14:48] |
You have the correct exchange activated but we realize we need to do a software update to allow that particular exchange fee to provide access to these new CME micro stock index futures symbols. This will be done at the end of the day today.
[2019-05-13 10:52:37] |
User37462 - Posts: 31 |
Hi I can see live data (including DOM) for all 4 markets but SC loads history only for M2KM9 and MESM9, not for MNQM9 and MYMM9 - I get: Download failed. Could you check it please or should I ask my broker? |
[2019-05-13 14:51:09] |
We have resolved this. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings After that, re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
