Date/Time: Fri, 31 Jan 2025 10:48:08 +0000
Market Depth Historical Graph
View Count: 2220
[2019-05-04 14:58:00] |
User94606 - Posts: 327 |
I am trying to create a chart similar to "SC Market Depth Historical Chart" (see attachment) and it is not displaying the Bid/Ask sizes on a per bar basis even when I set the parameter "Show Quantity Numbers:" in Bars. What parameters are needed to recreate the same chart as the "SC Market Depth Historical Chart"? My current settings are displayed on "ES Chart" attachment Also, during the live trading hours, are the Bid/Ask sizes displayed on the Market Depth Historical Graph considered live or historical/executed orders? Also, in the "SC Market Depth Historical Chart", how do I display the current quote window in a condensed and horizontal view (see red arrow) in "SC Market Depth Historical Chart" Date Time Of Last Edit: 2019-05-04 15:09:50
ES Chart.jpg / V - Attached On 2019-05-04 14:55:46 UTC - Size: 442.86 KB - 785 views SC Market Depth Historical Chart.jpg / V - Attached On 2019-05-04 14:56:14 UTC - Size: 236.79 KB - 1093 views |
[2019-05-04 17:37:01] |
EdCarp - Posts: 25 |
The Market Depth Historical Graph displays exactly what's on the DOM. These are resting orders. If you want to see actual traded bid/ask volume, you can add the Numbers Bars study to your chart.
[2019-05-04 17:43:11] |
Thanks. In the "SC Market Depth Historical Chart" attachment, how do I display the current quote window in a condensed and horizontal view (see red arrow) in "SC Market Depth Historical Chart"
[2019-05-04 21:55:23] |
John - SC Support - Posts: 37621 |
Refer to the following: Chart Drawing Tools: Horizontal Compact Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-04 22:34:27] |
I followed the instructions on the reference but it does not work. I am currently running version 1908
[2019-05-05 15:20:49] |
Please ignore last post. The current quote window is displaying in a horizontal view now. Thank you |
[2019-05-05 16:07:19] |
The Current Quote window does not support displaying horizontally. Only the Compact Tool Values Window. There probably is confusion as to what window you are looking at and its name. it is not displaying the Bid/Ask sizes on a per bar basis even when I set the parameter "Show Quantity Numbers:" in Bars. We are not sure why there is this issue. Post that chart by following these instructions:Support Board Posting Information: Providing Chartbook with Only a Single Chart The Market Depth Historical Graph only displays the limit orders that have not executed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-05 16:08:09
[2019-05-05 16:22:31] |
Thanks for the clarification on Tool Values window. I also figured the issue regarding "it is not displaying the Bid/Ask sizes on a per bar basis even when I set the parameter "Show Quantity Numbers:" in Bars. I think it only display the numbers during live market hours Thank you |
