Date/Time: Thu, 26 Sep 2024 23:30:01 +0000
[User Discussion] - Auto Fibs
View Count: 1666
[2013-11-23 20:28:09] |
Jerry J Sears - Posts: 27 |
Hi is there any way to use Auto Fib with the Swing high and low indicator. Or it have the ability to select indicator along with high or low. Let me know, Thanks, Jerry |
[2013-11-23 23:01:12] |
No.
