Date/Time: Fri, 31 Jan 2025 12:04:08 +0000
Opening Chart Book At Login
View Count: 983
[2019-05-04 02:41:30] |
User116783 - Posts: 84 |
Hi, How do you open a specific chartbook as soon as you log in to Sierra Chart? Thanks, ZS |
[2019-05-04 03:40:25] |
Refer to: General Settings Window: Select Files to Open On Startup (Global Settings >> General Settings >> General >> Startup) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
