Date/Time: Fri, 31 Jan 2025 12:12:13 +0000
Key to Escape Modify Text Box
View Count: 869
[2019-05-03 22:19:15] |
Kiwi - Posts: 375 |
Apologies for saying Escape in the header. Escape works, abandoning any work that's been done. I am looking to close the box completing the work. When I right click on typed text & select Modify Text it opens a box Text Properties With the original typed text entry box, Enter Text, its easy to automate it because Tab exits the box & puts you on the OK button. With the Text Properties, Tab just reselects the text. I can't find a key that will get me out of the box so the mouse is required (ugly rat tailed tendon ruiner that it is). Is there are key to get out of the box? If not, when you have a chance would you be kind enough to change the behaviour of Tab so that it exits to the OK button. Thanks :) Date Time Of Last Edit: 2019-05-03 22:28:40
