Date/Time: Fri, 31 Jan 2025 12:11:24 +0000
[Programming Help] - Trade Management by study inquiry
View Count: 849
[2019-05-03 19:40:56] |
User917679 - Posts: 76 |
How would one go about matching the trade quantity from their spreadsheet, to that of the attached order(that will be managed by a study)? Is this even possible? As of right now, it seems like I have to manually set a specific quantity of that order between every trade(?).. Edit: Seems to be working fine now; not sure how though.. Date Time Of Last Edit: 2019-05-04 19:31:04
[2019-05-05 15:44:47] |
In the case of when using the Spreadsheet System for Trading study, the attached orders will have the same quantity as the parent order. The parent order quantity can be set with this cell: Spreadsheet Systems, Alerts and Automated Trading: Order Quantity [J26] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-05 15:45:01
